05-07-2015 01:28 AM - last edited on 03-25-2019 08:34 PM by ciscomoderator
Hi I am using CUCM 10.5 with 8851 phones. I have noticed when press call foward all softkey on the phone and afterwards a speed dial button as call forward all destination the phone starts a normal call to the speed dial number and doesn't set it as call forward destination.
Is there an option to bring back the "old style" behavior from other phone series?
05-07-2015 05:52 AM
Hi Steffen,
have you a speed dial or BLF Speed Dial?
I think that to work how you want, phone needs a BLF Speed Dial.
Try and let me know if it works.
Andrea
05-07-2015 05:58 AM
It's a normal speed dial, no BLF speed dial. And it short work with normal speed dials which are configured with external phone numbers, like mobile numbers throug endusers self-service Portal
05-07-2015 06:27 AM
I made some test on my 8851 phone
If I config a speed dial with an internal number, and click only apply config, speed dial works correct, but if I want activate Call forward All and then press this speed dial, phone start a new call. Instead If I click Reset or restart after apply config, it works correct and Call Forward All permit to use also speed dial.
Have you tried to restart phone from phone page configuration?
05-07-2015 07:12 AM
After I restarted a phone I could re-use a speed dial as call-forward destination.
It sounds like bug, because when users are adding speed dials with self-service the phone update is just an "apply config". So I am afraid I will run again in this issue.
05-07-2015 07:18 AM
i also think that it is a bug. You can open a Tac for this bug if you have a service contract. If you haven't, I can open it for you hoping that Cisco solve this Bug in future firmware.
Rate useful post, thanks.
have a nice day
