02-23-2014 06:39 PM - edited 03-16-2019 09:52 PM
In Call Manager, I set a phone to forward to another phone. However, when I test it, it is not forwarding. Is there a service that might need restarted or are there some more basic elements I might need to check?
02-23-2014 06:42 PM
No, thats it. Make sure the change shows in CCMadmin, and also that replication is working fine
02-23-2014 09:43 PM
In addition ensure the forwarding CSSes are setup properly with access to the forwarded destination.
Chris
02-23-2014 11:46 PM
In addition to Jamie & Chris' answers, check that you're setting the right CallForward!
GTG
Please rate all helpful posts.
02-24-2014 12:26 AM
In addition to what Jaime, Chris and Gordon suggested, check the calling search space activation policy value which by default is with configured css
Carlo
02-24-2014 01:25 AM
Apart from what all the genious suggested, check by dialing the same number from the same phone who is forwarding.
Also what error you are getting while call fails?
Are you trying to forward the call internally or to external destination?
Nishant Savalia
02-24-2014 01:48 AM
Hello Laurel,
Also please check if this extension used in a hunt group, cause it won't work
Mohamed Helmy
02-24-2014 09:23 AM
When I went into work I could see that the extension is actually forwarding, but it returns to the forwarded phone'a voicemail which we don't want. We would like it so that callers can leave a message on the extension where the phone is forwarded. But I don't know if that is an option. CSS is set correctly. Is there something in Unity that might take care of the issue? I am not getting any errors
Thank you for all responses!!
02-24-2014 10:27 AM
Hi Laurel,
is it a unity connection installation ?
Are the unity connection configure via SIP or SCCP ?
If SIP is configure look into the SIP Trunk
Stefan
02-24-2014 10:52 AM
Hi Laurel,
+5 to all my friends here
You can have a look into this "System-wide" setting which is available in Unity Connection 7.x & later ;
Via
Cisco Unity Connection Administration
Advanced (towards the bottom of the page)
Conversation Configuration
**Use Last (Rather than First) Redirecting Number for Routing Incoming Call**
You would need to think about what impact this might have on your overall setup, but it does allow
for users to Forward to their personal VM at times and to achieve your secondary requirement as well
Cheers!
Rob
"May your heart always be joyful
And may your song always be sung
May you stay forever young "
- Dylan
