03-06-2019 10:03 AM - edited 03-07-2019 05:38 AM
I have a user who is requesting the below functionality:
Phone A (Internal VoIP or External)
Phone B (Internal VoIP)
Phone C (External)
Phone B and C have different phone numbers. We're running CUCM version 10.5
Phone B is configured to forward all calls to Phone C. When Phone A calls Phone B, the call is forwarded to Phone C. If Phone C does not answer they want to see a missed call notification on Phone B (which includes Phone A's phone number). I'm not sure if this is possible but wanted to ask before I tell them it can't be done.
* Update*
I found a workaround: Set Phone B to only forward calls on no-answer and set the no-answer for that DN to 1 ring.
Solved! Go to Solution.
03-06-2019 11:30 AM
That's not possible, for a phone to have a missed call, it has to ring, and with CFA that does not happen.
03-06-2019 10:36 AM - edited 03-06-2019 10:37 AM
Hi there
Please see if Missed call Notifications device section can play you the trick
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
03-06-2019 10:40 AM
03-06-2019 11:30 AM
03-06-2019 11:45 AM
