Highlighted
Explorer
Call Forward No Answer/Busy
I need to configure No Answer. Busy for a phone to ring to 3 different phones in CUCM instead of just one number.  Can someone tell me the best way to go about this?
All replies rated!
2 REPLIES 2
Hall of Fame Cisco Employee
Re: Call Forward No Answer/Busy
Send the call to a line group.
java
if this helps, please rate
VIP Advisor
It was already mentioned, but you would specify the phone number for a Hunt Pilot in the forwarding section of the original phone's Directory Number, and make sure the CSS on the Directory Number page, to the right of where you type in the phone number, can reach the partition of your Hunt Pilot.
If you've never configured a Hunt Pilot before, you actually do it in reverse order:
  1. Create a Line Group and Assign Members (set to Broadcast)
  2. Create a Hunt List and associate the Line Group
  3. Create a Hunt Pilot and associate the Hunt List
Good luck.
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
Content for Community-Ad
August's Community Spotlight Awards
