Beginner
Call forward on fxs
Hi I have a client with a UC540, who wants to divert incoming calls to an external number. The problem is that when the client makes this divert the caller hears a tone, ten seconds of silence and more tones (the external number does not start ringing until these last ten seconds.). The lines are fxs. How i  could reduce that time?
10 REPLIES 10
Highlighted
Advocate
Call forward on fxs
This sounds like you are using the default inter digit timer of 10 secs
Try adjusting this
on cli config
telephony-service
timeout interdigit 4
Alex
Regards, Alex. Please rate useful posts.
Highlighted
Beginner
Call forward on fxs
thanks for the reply, but i have a timeout interdigit 5. Another idea?
Highlighted
Advocate
Re: Call forward on fxs
Can you post the config
Show run
Can you also state the FXS port  and the forwarded number
Alex
Highlighted
Beginner
Here is the shrun
Highlighted
Advocate
I am assuming that the outgoing call forward goes to the PDTN via the FXO ports
Can you add
voice-port 0/1/0
timeouts interdigit 5
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
Alex
Highlighted
Beginner
Call forward on fxs
Yes, client only have two fxo lines. Inbound calls from analog pstn line are forwarded to analog gsm gateway conected to fxo port.
Highlighted
Advocate
Call forward on fxs
Did adding the additional config help ?
Alex
Highlighted
Beginner
Call forward on fxs
The problem persists. Could it be that the UC, look for line in all FXO ports?
Highlighted
Advocate
Call forward on fxs
What is the delay like when you dial direct to the target number
Alex
Highlighted
Beginner
Call forward on fxs
Yes is delayed, I will try to  change the gsm gateway, because it seems to hang randomly.
Thanks for your support.
