Highlighted
Beginner
Call forward to a Different number
Hi im trying to forward a 888 number to a 973 so when i get the sip call to my as5400xm gateway i can forward it to 973 number. Im not sure how to edit my dial peers for this.
                                  Forwards call from 888 the Main office
         caller------Sip carrier-------as54000---------PBX Scenario 1
(calls 888 number)                                |------------Main office(97321880000)Scenario 2
5 REPLIES 5
VIP Advisor
Re: Call forward to a Different number
Can you add your current config to the post please
Please remember to rate useful posts, by clicking on the stars below.
Beginner
These are the rules and Dial peers in place what we need is just one number to route to 9732188000 so the clients that call the 888 number route to a external location number (9732188000) and not to where our pbx is.
voice translation-rule 1
rule 1 /8887830300/ /9732188000/
voice translation-profile Transfer888
translate called 1
dial-peer voice 28 pots
trunkgroup voip
destination-pattern .T
dial-peer voice 99 voip
voice cut-through alert
session protocol sipv2
incoming called-number .T
voice-class codec 99
dtmf-relay rtp-nte
no vad
dial-peer voice 100 voip
description outgoing
destination-pattern [2-9].........
session target ipv4:23.29.23.68
dtmf-relay rtp-nte
no vad
dial-peer voice 29 pots
preference 8
clid network-number 8883903955
port 7/0:26:D
dial-peer voice 30 pots
preference 9
port 7/0:27:D
dial-peer voice 31 pots
preference 10
port 7/0:28:D
dial-peer voice 101 voip
translation-profile incoming Transfer888
destination-pattern 8887830300
dtmf-relay rtp-nte
no vad
dial-peer voice 32 pots
translation-profile outgoing Transfer888
dial-peer hunt 1
destination-pattern 8887830300$
dtmf-relay rtp-nte
no vad
Could you please try to change the destination pattern as shown above? and let me know whats the status.
Enthusiast
From your description, it seems you need to add voice translation rule and profile to convert your 888 number to 973 number on your GW and then have dial peer with appropriate pattern and destination to do whatever you want to do with the call.
Beginner
Example please review my update
Content for Community-Ad
July's Community Spotlight Awards
