01-27-2020 09:11 AM
Dear All,
I am trying to achieve the following requirement with ‘Hunt Group’.
Requirement:
When Hunt Pilot 5777 is dialed out -- it should ring (Broadcast Algorithm) on 3 phones (phone1, phone2 & phone3) if no answer or busy -- the call should then forward to the next set of phones (Broadcast Algorithm - phone4, phone5 & phone6) if no answer or busy -- the call should further go to the next set of phones (Broadcast Algorithm - phone7 & phone8) if no answer or busy -- the call should go to final destination ‘phone9’.
I tried the following but failed.
Created four Hunt Groups and added the lines
Created four Hunt Lists and added the Groups
Created Hunt Pilot 5777 -- selected Test-HL1
Test Result:
Call ‘5777’, phone1, phone2 & phone3 are ringing -- call forwarding to next group and ending after second group.
Not sure why it is not working. Could you assist me, please?
Solved! Go to Solution.
01-27-2020 01:45 PM
Sounds like it's working as configured, if your 5777 hunt pilot points to Test-HL1 which has only 2 line groups in it, then it will only hunt through those. If you need to hunt all 4 line groups then add them to your hunt list in desired order.
01-27-2020 01:45 PM
01-27-2020 09:26 PM
Yes, that worked.
Appreciate your help.
Cheers.
