Call forward
Need help to design the below call fow
We want to forward only external calls to some other extension with out any ring.
All the internal calls should land on the same extension. Please help!
6 Replies 6
Hi Mohammed.
You can configure a tanslation Pattern with the DID of extensions you want to forward.
Put these TP in a partition matched VG's incoming CSS only
Give to these TP a valid css in order to let them to call "Called Party Transform Mask"
Carlo
Please rate all helpful posts "The more you help the more you learn"
Thank you very much Carlo.
Pls let me know whether TP can be used for incoming calls also?
ex.: call from mobile to DID number can be translated to another internal number (Station)?
Hi Mohammed.
Absolutely yes :)
TP are mainly used to translate incoming calls from the PSTN
EG.
Called nr . 065551234
My Ext 1234
TP Config
Pattern: 06555XXXX
Partition : Internal
CSS: Internal_Only
Called Party Transform Mask : XXXX
Carlo
Hi Carlo,
Many thanks for your inputs, Will check the same.
We are using MGCP gateway, Unable to find any CSS in the CUCM configuration.
Can you please let me know why VG css is required. CZ able to see gateway CSS in our CSS list for all locations.
Hi Mohammed.
On MGCP setup, you can find incoming CSS on Port configuration.
With CSS you can manage which DN or Pattern your VG would be able to reach.
If don't have any partition configured on your CUCM, you can avoid this step.
Carlo
Many thanks Carlo!!
