Call Forwarded back to SIP trunk has no audio both ways
zkzqzk0730
When CFwdALL is set up on our internal phone to an external number,all incoming calls to this internal phone will be automatically forwarded to the selected external number. The external number will wring, but after answer the call, there is no audio both ways. All other types of calls work fine.   Please help...
Below is the configuration under VOICE SEVICE VOIP
voice service voip
 ip address trusted list
  ipv4 60.234.xxx.xxx
 mode border-element
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service h450.2
 no supplementary-service h450.3
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server expires max 600 min 60
  redirect contact order best-match
  outbound-proxy ipv4:60.234.xxx.xxx
11 Replies 11
Wilson Samuel
Level 7
Level 7
I would like to get the outputs from the following debugs :
1. debug voice ccapi inout
2. debug ccssip messages
Thanks for helping.
I made two test call and ran the Debug respectively. Automatic Call forward to 0210378955 is setup on 09 3027393.
Test Call is from 02102598760 to 09 3027393, so it was forwarded to  0210378955 , it ringed, but no audio both ways after answer.
Here is the debug output.
Debug output for CCSIP Message:
Log Buffer (8192 bytes):
67: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
223682: Jul 29 22:26:27.867:  vsacount in free is 0
223683: Jul 29 22:28:10.811: %VOICE_IEC-3-GW: H323: Internal Error (Socket error): IEC=1.1.186.5.7.5 on callID
-1
223684: Jul 29 22:29:22.891: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   ccAppShutdownMode: remove it from the queue
223685: Jul 29 22:29:27.867: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
223686: Jul 29 22:31:15.946: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:093025801@T-cosc-auck1-sipt:5060 SIP/2.0
Via: SIP/2.0/UDP 60.234.xxx.xxx:5060;branch=z9hG4bKahofna30b0dhhr06s4c0.1
To: <sip:093025801@121.98.xxx.xxx;user=phone>
From: <sip:2102598760@60.234.xxx.xxx;user=phone>;tag=snl_0009627734_NSN_CLIENT
Call-ID: NSNSIP-2524140a-724140a-1-11-1438165887-432625-1438598512
CSeq: 1235 INVITE
Contact: <sip:2102598760@60.234.xxx.xxx:5060;transport=udp>
Content-Type: application/sdp
Content-Length: 172
Accept-Language: en;q=0.0
Allow: REGISTER, INVITE, ACK, BYE, CANCEL, NOTIFY, REFER
Supported: timer
Session-Expires: 1800;refresher=uac
Min-SE: 1800
Date: Wed, 29 Jul 2015 10:31:27 GMT
Max-Forwards: 69
P-Asserted-Identity: <sip:2102598760@10.20.46.39;user=phone>
Privacy: none
v=0
o=- 6379623 1 IN IP4 60.234.xxx.xxx
s=-
c=IN IP4 60.234.xxx.xxx
t=0 0
m=audio 30000 RTP/AVP 8 0 100
a=fmtp:100 0-15
a=ptime:20
a=rtpmap:100 telephone-event/8000
223687: Jul 29 22:31:15.950: //2697715/C6BB0659A7BC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 29 Jul 2015 10:31:15 GMT
CSeq: 1235 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
223688: Jul 29 22:31:15.962: //2697716/C6BC3EA9A7C1/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0210378955@60.234.xxx.xxx:5060 SIP/2.0
Via: SIP/2.0/UDP 121.98.xxx.xxx:5060;branch=z9hG4bK1C672C73
From: "xxx_LTD." <sip:93027393@121.98.xxx.xxx>;tag=291DCE28-DDC
To: <sip:0210378955@60.234.xxx.xxx>
Call-ID: C6BCDAD1-351311E5-A7C59F72-2F8A3F15@121.98.xxx.xxx
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3334225577-0890442213-2814484338-0797589269
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1438165875
Contact: <sip:93027393@121.98.xxx.xxx:5060>
Diversion: <sip:093025801@121.98.xxx.xxx>;privacy=off;reason=unconditional;counter=1;screen=no
Expires: 180
Max-Forwards: 68
Content-Disposition: session;handling=required
Content-Length: 252
v=0
o=CiscoSystemsSIP-GW-UserAgent 1999 527 IN IP4 121.98.xxx.xxx
s=SIP Call
c=IN IP4 121.98.xxx.xxx
t=0 0
m=audio 30036 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
223689: Jul 29 22:31:15.966: //2697716/C6BC3EA9A7C1/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
223690: Jul 29 22:31:21.578: //2697716/C6BC3EA9A7C1/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:0210378955@60.234.xxx.xxx>;tag=snl_0009603487
CSeq: 101 INVITE
Contact: <sip:0210378955@60.234.xxx.xxx:5060;transport=udp>
Date: Wed, 29 Jul 2015 10:31:34 GMT
Content-Length: 171
v=0
o=- 32106090 1 IN IP4 60.234.xxx.xxx
s=-
t=0 0
m=audio 30060 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
223691: Jul 29 22:31:21.578: //2697715/C6BB0659A7BC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:093025801@121.98.xxx.xxx;user=phone>;tag=291DE41C-1BD
CSeq: 1235 INVITE
Contact: <sip:0210378955@121.98.xxx.xxx:5060>
Content-Length: 0
223692: Jul 29 22:31:23.670: //2697716/C6BC3EA9A7C1/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Require: timer
Date: Wed, 29 Jul 2015 10:31:36 GMT
Content-Length: 171
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
223693: Jul 29 22:31:23.674: //2697716/C6BC3EA9A7C1/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:0210378955@60.234.xxx.xxx:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 121.98.xxx.xxx:5060;branch=z9hG4bK1C6732514
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
223694: Jul 29 22:31:23.678: //2697715/C6BB0659A7BC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1235 INVITE
Contact: <sip:093025801@121.98.xxx.xxx:5060>
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 252
v=0
o=CiscoSystemsSIP-GW-UserAgent 5424 273 IN IP4 121.98.xxx.xxx
s=SIP Call
t=0 0
m=audio 25804 RTP/AVP 0 100
a=fmtp:100 0-15
a=ptime:20
223695: Jul 29 22:31:23.690: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:093025801@121.98.xxx.xxx:5060 SIP/2.0
Via: SIP/2.0/UDP 60.234.xxx.xxx:5060;branch=z9hG4bK84dqn1307omhr1l20701.1
CSeq: 1235 ACK
Date: Wed, 29 Jul 2015 10:31:35 GMT
Max-Forwards: 69
Content-Length: 0
Route: <sip:121.98.xxx.xxx;lr>
Debug Output for VOICE CCAPI INOUT
Jul 29 22:32:48.858: //2697718/FA5DF474A7C6/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=2697718,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
223789: Jul 29 22:32:48.858: //2697718/FA5DF474A7C6/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
223790: Jul 29 22:32:48.858: //2697717/FA5DF474A7C6/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=2697718, Source Call Id=2697717,
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
223791: Jul 29 22:32:48.858: //2697717/FA5DF474A7C6/CCAPI/cc_api_caps_ack:
   Caps(Codec=gsmefr(0x0), Fax Rate=Invalid(0x0), Vad=Invalid(0xFFFFFFFF),
   Modem=Invalid(0xFFFFFFFF), Codec Bytes=0, Signal Type=-1, Seq Num Start=-1)
223792: Jul 29 22:32:48.858: //2697718/FA5DF474A7C6/CCAPI/cc_api_event_indication:
   Event=168, Call Id=2697718
223793: Jul 29 22:32:48.858: //2697718/FA5DF474A7C6/CCAPI/cc_api_event_indication:
   Event Is Sent To Conferenced SPI(s) Directly
223794: Jul 29 22:32:48.858: //2697718/FA5DF474A7C6/CCAPI/cc_api_call_connected:
   Interface=0x30964AB4, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
223795: Jul 29 22:32:48.858: //2697718/FA5DF474A7C6/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
223796: Jul 29 22:32:48.858: //2697717/FA5DF474A7C6/CCAPI/ccConferenceCreate:
   (confID=0x2C638718, callID1=0x2929F5, gcid=FA5E909C-351311E5-A7C99F72-2F8A3F15, tag=0x0)
223797: Jul 29 22:32:48.858: //2697718/FA5DF474A7C6/CCAPI/ccConferenceCreate:
   (confID=0x2C638718, callID2=0x2929F6, gcid=FA5E909C-351311E5-A7C99F72-2F8A3F15, tag=0x0)
223798: Jul 29 22:32:48.858: //2697717/FA5DF474A7C6/CCAPI/ccConferenceCreate:
   Conference Id=0x2C638718, Call Id1=2697717, Call Id2=2697718, Tag=0x0
223799: Jul 29 22:32:48.858: //2697717/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
223800: Jul 29 22:32:48.858: cc_api_get_xcode_stream : 4702
223801: Jul 29 22:32:48.858: //2697718/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
223802: Jul 29 22:32:48.858: cc_api_get_xcode_stream : 4702
223803: Jul 29 22:32:48.858: //2697717/FA5DF474A7C6/CCAPI/ccConferenceCreate:
223804: Jul 29 22:32:48.858: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=1, dtmf1=6
                    ret2=0, codecMask2=1, bytes2=160, negot2=1, dtmf2=6,
                    tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
                    tx_dynamic_pt2=0, rx_dynamic_pt2=0, codec_mode2=0, params_bitmap2 =0
223805: Jul 29 22:32:48.858: //2697717/FA5DF474A7C6/CCAPI/ccConferenceCreate:
   delay media to slow start case, codec negotation is not done
223806: Jul 29 22:32:48.858: //2697717/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
223807: Jul 29 22:32:48.858: cc_api_get_xcode_stream : 4702
223808: Jul 29 22:32:48.858: //2697717/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
223809: Jul 29 22:32:48.858: cc_api_get_xcode_stream : 4702
223810: Jul 29 22:32:48.858: //2697717/FA5DF474A7C6/CCAPI/cc_api_bridge_done:
   Conference Id=0xDC46, Source Interface=0x30964AB4, Source Call Id=2697717,
   Destination Call Id=2697718, Disposition=0x0, Tag=0x0
223811: Jul 29 22:32:48.858: //2697718/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
223812: Jul 29 22:32:48.858: cc_api_get_xcode_stream : 4702
223813: Jul 29 22:32:48.858: //2697718/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
223814: Jul 29 22:32:48.858: cc_api_get_xcode_stream : 4702
223815: Jul 29 22:32:48.858: //2697718/FA5DF474A7C6/CCAPI/cc_api_bridge_done:
   Conference Id=0xDC46, Source Interface=0x30964AB4, Source Call Id=2697718,
   Destination Call Id=2697717, Disposition=0x0, Tag=0x0
223816: Jul 29 22:32:48.858: //2697717/FA5DF474A7C6/CCAPI/cc_generic_bridge_done:
223817: Jul 29 22:32:48.858: //2697717/FA5DF474A7C6/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xDC46, Destination Call Id=2697718)
223818: Jul 29 22:32:48.858: //2697718/FA5DF474A7C6/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xDC46, Destination Call Id=2697717)
223819: Jul 29 22:32:48.862: //2697717/FA5DF474A7C6/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xDC46, Call Id1=2697717, Call Id2=2697718
223820: Jul 29 22:32:48.862: //2697717/FA5DF474A7C6/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
223821: Jul 29 22:32:48.862: //2697717/FA5DF474A7C6/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
223822: Jul 29 22:32:59.053: //2697718/FA5DF474A7C6/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=2697718
223823: Jul 29 22:32:59.053: //2697717/FA5DF474A7C6/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x30964AB4, Call Id=2697717
223824: Jul 29 22:32:59.053: //2697717/FA5DF474A7C6/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
223825: Jul 29 22:32:59.053: //2697717/FA5DF474A7C6/CCAPI/ccConferenceDestroy:
   Conference Id=0xDC46, Tag=0x0
223826: Jul 29 22:32:59.053: //2697717/FA5DF474A7C6/CCAPI/cc_api_bridge_drop_done:
223827: Jul 29 22:32:59.053: //2697718/FA5DF474A7C6/CCAPI/cc_api_bridge_drop_done:
223828: Jul 29 22:32:59.053: //2697717/FA5DF474A7C6/CCAPI/cc_generic_bridge_done:
223829: Jul 29 22:32:59.057: //2697717/FA5DF474A7C6/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
223830: Jul 29 22:32:59.057: //2697717/FA5DF474A7C6/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
223831: Jul 29 22:32:59.057: //2697718/FA5DF474A7C6/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
223832: Jul 29 22:32:59.057: //2697718/FA5DF474A7C6/CCAPI/ccCallDisconnect:
223833: Jul 29 22:32:59.057: //2697717/FA5DF474A7C6/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30964AB4, Tag=0x0, Call Id=2697717,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
223834: Jul 29 22:32:59.057: //2697717/FA5DF474A7C6/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
223835: Jul 29 22:32:59.057: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
223836: Jul 29 22:32:59.057: :cc_free_feature_vsa freeing 2A7DE4D8
223837: Jul 29 22:32:59.057: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
223838: Jul 29 22:32:59.057:  vsacount in free is 3
223839: Jul 29 22:32:59.057: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
223840: Jul 29 22:32:59.057:  vsacount in free is 2
223841: Jul 29 22:32:59.069: //2697718/FA5DF474A7C6/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30964AB4, Tag=0x0, Call Id=2697718,
223842: Jul 29 22:32:59.069: //2697718/FA5DF474A7C6/CCAPI/cc_api_call_disconnect_done:
223843: Jul 29 22:32:59.069: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
223844: Jul 29 22:32:59.069: :cc_free_feature_vsa freeing 2A7DDEB8
223845: Jul 29 22:32:59.069: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
223846: Jul 29 22:32:59.069:  vsacount in free is 1
223847: Jul 29 22:32:59.069: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
223848: Jul 29 22:32:59.069:  vsacount in free is 0
Please apply this config:
voice service voip
Please make a test call, share the calling/called numbers, once the call connected share the output of the following:
1. sh voip rtp conn
2. sh call acti vo br
3. sh sccp conn
If i apply supplementary-service sip moved-temporarily , the call can not be connected. So i ran the test without applying this command.
Test Call is from 02102598760 to 09 3027393. Automatic forwarding to 0210378955 was set on 09 3027393 , so the call was forwarded to  0210378955 . It ringed, but no audio both ways after answer.
CoscoCME#show voip rtp connections
VoIP RTP active connections :
No. CallId     dstCallId  LocalRTP RmtRTP     LocalIP                                RemoteIP
1     2726686    2726687    17818    30196    121.98.xxx.xxx                         60.234.xxx.xxx
2     2726687    2726686    16530    30022    121.98.xxx.xxx                         60.234.xxx.xxx
Found 2 active RTP connections
CoscoCME#show call active voice brief
<ID>: <CallID> <start>.<index> +<connect> pid:<peer_id> <dir> <addr> <state>
  dur hh:mm:ss tx:<packets>/<bytes> rx:<packets>/<bytes>
 IP <ip>:<udp> rtt:<time>ms pl:<play>/<gap>ms lost:<lost>/<early>/<late>
  delay:<last>/<min>/<max>ms <codec>
 media inactive detected:<y/n> media cntrl rcvd:<y/n> timestamp:<time>
 long duration call detected:<y/n> long duration call duration :<sec> timestamp:<time>
  MODEMPASS <method> buf:<fills>/<drains> loss <overall%> <multipkt>/<corrected>
   last <buf event time>s dur:<Min>/<Max>s
 FR <protocol> [int dlci cid] vad:<y/n> dtmf:<y/n> seq:<y/n>
  <codec> (payload size)
 ATM <protocol> [int vpi/vci cid] vad:<y/n> dtmf:<y/n> seq:<y/n>
 Tele <int> (callID) [channel_id] tx:<tot>/<v>/<fax>ms <codec> noise:<l> acom:<l> i/o:<l>/<l> dBm
  MODEMRELAY info:<rcvd>/<sent>/<resent> xid:<rcvd>/<sent> total:<rcvd>/<sent>/<drops>
         speeds(bps): local <rx>/<tx> remote <rx>/<tx>
 Proxy <ip>:<audio udp>,<video udp>,<tcp0>,<tcp1>,<tcp2>,<tcp3> endpt: <type>/<manf>
 bw: <req>/<act> codec: <audio>/<video>
  tx: <audio pkts>/<audio bytes>,<video pkts>/<video bytes>,<t120 pkts>/<t120 bytes>
 rx: <audio pkts>/<audio bytes>,<video pkts>/<video bytes>,<t120 pkts>/<t120 bytes>
Telephony call-legs: 0
SIP call-legs: 3
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 3
2DEC : 2726686 20:19:15.347 NZST Tue Aug 4 2015.1 +4980 pid:203 Answer 2102598760 active
 dur 00:00:32 tx:0/0 rx:0/0
 IP 60.234.18.159:30196 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
 media inactive detected:n media contrl rcvd:n/a timestamp:n/a
 long duration call detected:n long duration call duration:n/a timestamp:n/a
2DF1 : 2726687 20:19:15.371 NZST Tue Aug 4 2015.1 +4940 pid:1004 Originate 0210378955 active
 IP 60.234.18.159:30022 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
2DF6 : 2726688 20:19:36.841 NZST Tue Aug 4 2015.1 +-1 pid:203 Answer 2011 connecting
 dur 00:00:00 tx:0/0 rx:0/0
 IP 69.30.230.90:5072 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
SIP call-legs: 3
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 3
CoscoCME#show sccp connections
Total number of active session(s) 0, and connection(s) 0
Hi did you find a solution to this issue. Can you share what you did to resolve it
Please rate all useful posts
Dennis Mink
Waiting for you ccsip debugs, meanwhile, this typically sounds like either a routing/connectivity issue or failing to negotiate codec. I am guessing the first.
Your debug information should contain SDP's with connecting IP addresses for the RTP media stream,  check that info and verify connectivity,
Please remember to rate useful posts, by clicking on the stars below.
Please see below debug...
Also, can you please share the CUBE config.
Sorry, what is CUBE config?..
router config
zkzqzk0730
Can anyone please help?...
