12-19-2011 02:00 PM - edited 03-16-2019 08:36 AM
We have an issue at one of our locations .
Whenever there is call being forwarded to an outside cell phone number from turret phone at one of our location it doesn’t work. (for caller) Call disconnect after almost 1 minutes of Silence. (For final called pary) his phone rings for just second and disconnect and process repeats and lasts about 1 minute.
As per gateway debugs, we see a setup being received.
040944: *Dec 15 22:10:53.114 UTC: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0F4A
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9F8B0100A10F02013006072A8648CE1500040A0100
Protocol Profile = Networking Extensions
0xA10F02013006072A8648CE1500040A0100
Component = Invoke component
Invoke Id = 48
Operation = InformationFollowing (calling_name)
Name information in subsequent FACILITY message
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '214xxxxx51'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '3052'
Plan:Unknown, Type:Unknown
Then CM sends call setup to turret through another gateway.
040356: .Dec 15 22:17:05.507 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x03AE
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Channel ID i = 0xA9839F
Exclusive, Channel 31
Facility i = 0x9FAA06800100820100A1080201000201008400
Same gatway then receives setup back for the forwarded call (hairpin)
040947: *Dec 15 22:10:53.718 UTC: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0694
Sending Complete
Standard = CCITT
Channel ID i = 0xA98396
Exclusive, Channel 22
Facility i = 0x9FAA06800100820100A119020209D402011530100201010A0101A108A006800433303532
Calling Party Number i = 0x0083, '21xxxxxx51'
Called Party Number i = 0x80, '91.......388'
Call manager then forwards the call to telco
040949: *Dec 15 22:10:53.838 UTC: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8 callref = 0x050F
Standard = CCITT
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x2183, '21......51'
Called Party Number i = 0xA1, '171........88'
040950: *Dec 15 22:10:53.902 UTC: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x850F
For which we receive a progress ind from telco.
040951: *Dec 15 22:10:56.478 UTC: ISDN Se0/0/1:23 Q931: RX <- PROGRESS pd = 8 callref = 0x850F
Progress Ind i = 0x8288 - In-band info or appropriate now available
We receive no message for next 10 seconds.
After 10 seconds the call originating telco disconnects the call.
040953: *Dec 15 22:11:03.306 UTC: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x0F4A
Cause i = 0x80E6 - Recovery on timer expiry
collected traces for successful call hoever in that call telco doesn’t send call proc in response to set. It sends alerting.
In both good and bad call case call is going out through same circuit. That is 0/0/1 of srst gateway of the location.
Can somebody guide on this.
12-19-2011 03:48 PM
Are these H323 dialpeers. Have you adjusted the H225 call setup timers? Also have you adjusted callmanager to allow for additional call connect time? Seems from the call you are transverse a few gateways and the call connect is timing out.
The T310 Timer sets how long to wait to get a response such as ALERTING or CONNECT to a Call Proceeding message.
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094487.shtml
Cause i = 0x80E6 indicates timeout on a longdistance call. Looks like the carrier is looking for a connect mesg and does not recieve so it times out.
Mike
12-19-2011 04:03 PM
carrier sends a calls progressing note.. can attach the deubgs if u want.
