05-08-2013 06:59 AM - edited 03-16-2019 05:12 PM
I have a question about call forwarding and unforwarding.
As far as I know, there are 3 ways of doing this.
1.) If you access to CUCM, you can go to the phone and directory number and set the number under call forwarding.
2.) From your "own" Cisco phone, using the Forward All softkey
3.) If you have a CUCM user account, set the number under call forwarding.
My question is that I have operators that need to be able to call forward and unforward people's phones at times. I only want them to have access to forward and unforward a number for another user. Is there a way for them to do this from there Cisco phone?
I know that in CUCM I can restrict the operators to the phone/directory number level but they still have the potential to change other parameters such as the DN, Calling Search Space, and other parameters.
Thank You
05-08-2013 07:25 AM
No, that's not possible.
MLA is not that granular.
Not from the phone, nor from the CCMadmin.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-08-2013 07:54 AM
The only way that I can think of is to associate the user to the phones you want them to control, then for them to use the ccmuser page and chose the device from user options-->device.
Clunky, but can't think of another way at the moment.
Gareth
05-08-2013 08:00 AM
Hi.
An option is to associate to some end users all phones that you want to manage call forwarding and define them as cucm end user.
You could repeat this operation for all users you want to be able to forward calls for other users
Than.. the user access to http://<
Carlo
Please rate all helpful posts
"The more you help the more you learn"
