Call Forwarding - High Traffic
CUCM |IP Phone| Call forwarding to PSTN |mobile number| showing "High Traffic Try Again Later"!
12 Replies 12
What is your type of PSTN connection?
The number is correctly?
Only call forward thats not work?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
We have E1 PSTN connection...
The number is correct...
Internal call forward is working but call forward to PSTN |mobile|  is not working...
Thanks..
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Is it H323? If so can you post your dual peer config?
dial-peer voice 1 pots
translation-profile incoming VGW-in
incoming called-number .
direct-inward-dial
dial-peer voice 8000 voip
description System Extensions
destination-pattern 8...
session target ipv4:172.16.35.20
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 7000 voip
description 7 Range Extensions
destination-pattern 71[349].
codec g711ulaw
dial-peer voice 71380 pots
description ERP FAX
destination-pattern 7138T
port 0/3/0
dial-peer voice 20000 pots
trunkgroup Commscope
description Commscope Outgoing Lines
destination-pattern 9T
dial-peer voice 70000 pots
trunkgroup STC-BT
description BT Users-All Calls
destination-pattern 66T
dial-peer voice 80060 voip
description MeMega IVR
destination-pattern 8006
dial-peer voice 1759 pots
description POS Number for MeMega Showroom
destination-pattern 881759
port 0/3/1
forward-digits 4
dial-peer voice 1500 voip
description UCM Extensions
destination-pattern 1[154]..
codec g711ulaw
dial-peer voice 6900 pots
description Nortel E1 Range
destination-pattern 69..
port 2/1:0
forward-digits all
dial-peer voice 70010 pots
description Outgoing MeMega All Users
destination-pattern 88T
port 1/0:0
dial-peer voice 7020 voip
destination-pattern 7001
codec g711ulaw
dial-peer voice 15000 pots
description Outgoing for Cisco and Nortel Users
destination-pattern 55T
fax rate disable
port 1/0:0
dial-peer voice 5500 voip
destination-pattern 700T
codec g711ulaw
dial-peer voice 5600 pots
destination-pattern 56T
port 0/2/0
dial-peer voice 70291759 pots
destination-pattern 7029T
port 0/3/3
dial-peer voice 70301759 pots
destination-pattern 7030T
port 0/3/2
dial-peer voice 70311759 pots
destination-pattern 7031T
port 0/3/1
dial-peer voice 70321759 pots
destination-pattern 7032T
port 0/2/2
dial-peer voice 7129 voip
destination-pattern 7129
codec g711ulaw
fax-relay ecm disable
fax rate disable
dial-peer voice 7044 voip
description Memega FAX
destination-pattern 7044
dtmf-relay rtp-nte
codec g711ulaw
  dial-peer voice 77770 voip
description Cisco Call Center Nortel
destination-pattern 7777
session protocol sipv2
session target ipv4:172.16.2.74
codec g711alaw
dial-peer voice 6992 voip
destination-pattern 6917
session target ipv4:172.16.12.202
session transport udp
voice-class codec 2
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
no vad
dial-peer voice 550001 pots
forward-digits 4
dial-peer voice 90001 pots
destination-pattern 55.......,,,,,,,,,,T
fax rate disable
port 1/0:0
dial-peer voice 699251 pots
service faxd
shutdown
incoming called-number 6992
direct-inward-dial
dial-peer voice 66995522 voip
destination-pattern 6992
codec g711ulaw
fax rate disable
dial-peer voice 699253 voip
service faxd
shutdown
incoming called-number 4555
dial-peer voice 719444 voip
destination-pattern 7199
dtmf-relay rtp-nte
codec g711ulaw
clid network-provided
dial-peer voice 7194 voip
description to microsoft communication server
destination-pattern 57....
session target ipv4:172.16.100.111
session transport tcp
codec g711ulaw
dial-peer voice 69055 voip
description to microsoft communication server Conference
translation-profile outgoing MSConference
destination-pattern 6905
session target ipv4:172.16.100.240:5068
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 8794 voip
description BTAT IVR
destination-pattern 8794
dial-peer voice 6984 voip
description MVA for 7199
destination-pattern 6984
codec g711ulaw
no vad
dial-peer voice 69840 pots
service ccm
incoming called-number 6984
direct-inward-dial
dial-peer voice 17777 pots
description POTS FOR DOKKI
destination-pattern 605........
port 0/1/1
forward-digits 10
dial-peer voice 18888 pots
description POTS FOR NILE CITY
port 0/0/1
forward-digits 10
dial-peer voice 6969 voip
description ERP Support 1600
destination-pattern 6969
codec g711ulaw
Your destination-pattern destination-pattern 71[349]. is improperly formatted which will cuase this error (I know I've been there :-))
The syntex needs to be 71[3,4,9].
HTH, please rate all useful posts!
Chris
Chris
Your recommended solution seems to be not useful!
can you post the output of debug voice ccapi inout and your try to forward the call to cell phone number.
Leonardo Santana
Leonardo Santana
hi Marlo,
Possible to do a debug isdn q931? is the call successful sent to the GW?
TIA
actually, we are using E1-CAS and debug isdn q931 is not supported, and when i used [terminal monitor | debug voice ccapi inout] commands ...strange..no output..
Mario inside the Directory Number the CSS of Call Forward All has the permission to reach cell phones numbers route pattern?
Leonardo Santana
Leonardo Santana
i checked the CSS and there is mobile access|privilege..
Problem Solved :
Under CUCM H.323 Gateway Configuration:
Call Routing Information - Outbound Calls
Calling Party Selection* Originator
Recognize Your Peers
