07-26-2012 06:18 AM - edited 03-16-2019 12:23 PM
CUCM |IP Phone| Call forwarding to PSTN |mobile number| showing "High Traffic Try Again Later"!
07-26-2012 06:37 AM
What is your type of PSTN connection?
The number is correctly?
Only call forward thats not work?
Leonardo Santana
07-28-2012 12:48 AM
We have E1 PSTN connection...
The number is correct...
Internal call forward is working but call forward to PSTN |mobile| is not working...
Thanks..
07-28-2012 06:19 AM
Is it H323? If so can you post your dual peer config?
07-29-2012 01:19 AM
dial-peer voice 1 pots
translation-profile incoming VGW-in
incoming called-number .
direct-inward-dial
dial-peer voice 8000 voip
description System Extensions
destination-pattern 8...
session target ipv4:172.16.35.20
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 7000 voip
description 7 Range Extensions
destination-pattern 71[349].
codec g711ulaw
dial-peer voice 71380 pots
description ERP FAX
destination-pattern 7138T
port 0/3/0
dial-peer voice 20000 pots
trunkgroup Commscope
description Commscope Outgoing Lines
destination-pattern 9T
dial-peer voice 70000 pots
trunkgroup STC-BT
description BT Users-All Calls
destination-pattern 66T
dial-peer voice 80060 voip
description MeMega IVR
destination-pattern 8006
dial-peer voice 1759 pots
description POS Number for MeMega Showroom
destination-pattern 881759
port 0/3/1
forward-digits 4
dial-peer voice 1500 voip
description UCM Extensions
destination-pattern 1[154]..
codec g711ulaw
dial-peer voice 6900 pots
description Nortel E1 Range
destination-pattern 69..
port 2/1:0
forward-digits all
dial-peer voice 70010 pots
description Outgoing MeMega All Users
destination-pattern 88T
port 1/0:0
dial-peer voice 7020 voip
destination-pattern 7001
codec g711ulaw
dial-peer voice 15000 pots
description Outgoing for Cisco and Nortel Users
destination-pattern 55T
fax rate disable
port 1/0:0
dial-peer voice 5500 voip
destination-pattern 700T
codec g711ulaw
dial-peer voice 5600 pots
destination-pattern 56T
port 0/2/0
dial-peer voice 70291759 pots
destination-pattern 7029T
port 0/3/3
dial-peer voice 70301759 pots
destination-pattern 7030T
port 0/3/2
dial-peer voice 70311759 pots
destination-pattern 7031T
port 0/3/1
dial-peer voice 70321759 pots
destination-pattern 7032T
port 0/2/2
dial-peer voice 7129 voip
destination-pattern 7129
codec g711ulaw
fax-relay ecm disable
fax rate disable
dial-peer voice 7044 voip
description Memega FAX
destination-pattern 7044
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 77770 voip
description Cisco Call Center Nortel
destination-pattern 7777
session protocol sipv2
session target ipv4:172.16.2.74
codec g711alaw
dial-peer voice 6992 voip
destination-pattern 6917
session target ipv4:172.16.12.202
session transport udp
voice-class codec 2
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
no vad
dial-peer voice 550001 pots
forward-digits 4
dial-peer voice 90001 pots
destination-pattern 55.......,,,,,,,,,,T
fax rate disable
port 1/0:0
dial-peer voice 699251 pots
service faxd
shutdown
incoming called-number 6992
direct-inward-dial
dial-peer voice 66995522 voip
destination-pattern 6992
codec g711ulaw
fax rate disable
dial-peer voice 699253 voip
service faxd
shutdown
incoming called-number 4555
dial-peer voice 719444 voip
destination-pattern 7199
dtmf-relay rtp-nte
codec g711ulaw
clid network-provided
dial-peer voice 7194 voip
description to microsoft communication server
destination-pattern 57....
session target ipv4:172.16.100.111
session transport tcp
codec g711ulaw
dial-peer voice 69055 voip
description to microsoft communication server Conference
translation-profile outgoing MSConference
destination-pattern 6905
session target ipv4:172.16.100.240:5068
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 8794 voip
description BTAT IVR
destination-pattern 8794
dial-peer voice 6984 voip
description MVA for 7199
destination-pattern 6984
codec g711ulaw
no vad
dial-peer voice 69840 pots
service ccm
incoming called-number 6984
direct-inward-dial
dial-peer voice 17777 pots
description POTS FOR DOKKI
destination-pattern 605........
port 0/1/1
forward-digits 10
dial-peer voice 18888 pots
description POTS FOR NILE CITY
port 0/0/1
forward-digits 10
dial-peer voice 6969 voip
description ERP Support 1600
destination-pattern 6969
codec g711ulaw
07-29-2012 07:50 AM
Your destination-pattern destination-pattern 71[349]. is improperly formatted which will cuase this error (I know I've been there :-))
The syntex needs to be 71[3,4,9].
HTH, please rate all useful posts!
Chris
07-29-2012 11:46 AM
Chris
Your recommended solution seems to be not useful!
07-29-2012 05:25 PM
can you post the output of debug voice ccapi inout and your try to forward the call to cell phone number.
Leonardo Santana
07-29-2012 06:48 PM
hi Marlo,
Possible to do a debug isdn q931? is the call successful sent to the GW?
TIA
07-30-2012 04:21 AM
actually, we are using E1-CAS and debug isdn q931 is not supported, and when i used [terminal monitor | debug voice ccapi inout] commands ...strange..no output..
07-30-2012 05:04 AM
Mario inside the Directory Number the CSS of Call Forward All has the permission to reach cell phones numbers route pattern?
Leonardo Santana
07-30-2012 05:25 AM
i checked the CSS and there is mobile access|privilege..
07-31-2012 08:13 AM
Problem Solved :
Under CUCM H.323 Gateway Configuration:
Call Routing Information - Outbound Calls
Calling Party Selection* Originator
