Call Forwarding Returning to Orginal Voicemail
Katie85
How can I configure calls from UserA extension and UserB extension to ring a few times on their own phones and if they're not able to answer, forward to UserC, but if UserC cannot answer return to the original extension voicemail?
Example:  UserA -> forward to UserC -> UserC cannot answer -> call returns to UserA's voicemail?
I've seen some posts about hunt groups and call forwarding no coverage, but I cannot for the life of me get it working.
Running:
CUCM 11.0.1.21900-11
Cisco Unity Connection version: 11.0.1.21900-1
HARIS_HUSSAIN
1) Just forward the call to a voicemail from User-C Extension. The Unity Server will identify the Voicemail Box based on the First Redirecting Number by default I,e User A in your case.
You can change this to User C's Voicemail by changing the parameter in unity connection Under System Settings>Advanced>Conversations " Use Last (Rather than First) Redirecting Number for Routing Incoming Call".
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
Jaime Valencia
If C has a call forward set to VM, you would see that exact behavior by default.
java
if this helps, please rate
HARIS_HUSSAIN
Haris
Thanks so much for the note about the conversations setting in Unity. That was actually checked off and didn't even realize it. It's working now, thank you!
