10-19-2017 11:48 PM - edited 03-17-2019 11:26 AM
Hi All,
I am using my work number(jabber dekstop) to forward all the calls to my mobile number.
I notice when there is a external party calling my work number, it shows me wrong number on my mobile and my phone only ring for 2seconds then got cut off.
I tried using internal number (my colleagues work number) and it shows correct number and no cut off...
Can anyone advise where to check this settings in CUCM ?
Thank you very much in advance.
10-20-2017 11:52 AM
What is the number it displays, it is a BTN or any number associated with your DID block?
Is your out bound connection SIP? You could be having a rdnis issue or diversion header issue.
If you have a sip can you pull the debugs from the gateway of both calls in two different files.
If you are just call forwarding your not really messing with any timers if you are doing RDP and remote destinations then you can change the timers.
debug ccsip messages
10-23-2017 07:32 AM - edited 10-23-2017 07:40 AM
Hi Gregory,
I have run the debug and below is the output.. can you advise on the log ??? The calling number is 11111111 and the called number is 22222222 which i have forward to 33333333. Below is the log i have collect
*Oct 23 18:04:31.102: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+6522222222@shims.starhub.net.sg;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.31.119.249:5060;branch=z9hG4bKsbcthLNQu0IqLqpSb0uGbppSuunGInLpxT02445;Role=3;Dpt=8818_16
Call-ID: sbcthLNQnqlB6lpGBG0IpSSnanp0pBnIj6nGxbnb@g.V.LIa.4qGu4.41ZFqjl.K61.4S
From: <sip:11111111@shims.starhub.net.sg;user=phone>;tag=sbc0404sbcthLNQApFA4ai4-PP-B
To: <sip:+6522222222@shims.starhub.net.sg;user=phone>
CSeq: 1 INVITE
Allow: INVITE,ACK,BYE,CANCEL,UPDATE,INFO,PRACK,NOTIFY,REFER,SUBSCRIBE,OPTIONS,MESSAGE
P-Charging-Vector: icid-value=mgcf--20171023175127-100221720311190158833;term-ioi=kbscscf01.shims.starhub.net.sg
Max-Forwards: 65
Supported: 100rel,timer
Session-Expires: 1800
Min-SE: 600
P-Asserted-Identity: <sip:11111111@shims.starhub.net.sg;user=phone>
Contact: <sip:11111111@172.31.119.249:5060;Dpt=8818-400>
P-FNP-Capability: fnp
Content-Length: 222
Content-Type: application/sdp
v=0
o=- 42191250 42191250 IN IP4 172.31.119.251
s=SBC call
c=IN IP4 172.31.119.251
t=0 0
m=audio 17714 RTP/AVP 8 0 18 97
a=fmtp:18 annexb=no
a=rtpmap:97 telephone-event/8000
a=fmtp:97 0-15
a=ptime:20
a=sendrecv
*Oct 23 18:04:31.104: //-1/65A8F144B6E2/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=11111111
----- ccCallInfo IE subfields -----
cisco-ani=sip:11111111@shims.starhub.net.sg;user=phone
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=sip:+6522222222@shims.starhub.net.sg;user=phone
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFFFFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*Oct 23 18:04:31.104: //-1/65A8F144B6E2/CCAPI/cc_api_call_setup_ind_common:
Interface=0x7FF5F247E9C8, Call Info(
Calling Number=sip:11111111@shims.starhub.net.sg;user=phone,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=sip:+6522222222@shims.starhub.net.sg;user=phone(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=797107
*Oct 23 18:04:31.104: //-1/65A8F144B6E2/CCAPI/ccCheckClipClir:
In: Calling Number=sip:11111111@shims.starhub.net.sg;user=phone(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=sip:11111111@shims.starhub.net.sg;user=phone(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Oct 23 18:04:31.104: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 23 18:04:31.104: :cc_get_feature_vsa malloc success
*Oct 23 18:04:31.104: cc_get_feature_vsa count is 19
*Oct 23 18:04:31.104: :FEATURE_VSA attributes are: feature_name:0,feature_time:140694386398060,feature_id:35319
*Oct 23 18:04:31.104: //797107/65A8F144B6E2/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
*Oct 23 18:04:31.105: //797107/65A8F144B6E2/CCAPI/cc_process_call_setup_ind:
Event=0x7FF5F6EE5688
*Oct 23 18:04:31.105: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number +6522222222
*Oct 23 18:04:31.105: //797107/65A8F144B6E2/CCAPI/ccCallSetContext:
Context=0x7FF5FBEEA7A8
>>>>CCAPI handed cid 797107 with tag 10 to app "_ManagedAppProcess_Default"
*Oct 23 18:04:31.105: //797107/65A8F144B6E2/CCAPI/ccCallProceeding:
*Oct 23 18:04:31.105: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
mempool not found from usrContainer(7FF5FB72E518)
*Oct 23 18:04:31.105: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Mempool(7FF5FB7B3A60) created in usrContainer(7FF5FB72E518)
*Oct 23 18:04:31.105: //797107/65A8F144B6E2/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=20, Params=0x7FF5FB692E70, Progress Indication=NULL(0)
*Oct 23 18:04:31.106: //797107/65A8F144B6E2/CCAPI/ccCheckClipClir:
*Oct 23 18:04:31.106: //797107/65A8F144B6E2/CCAPI/ccCallSetupRequest:
Destination Pattern=+656914...., Called Number=+6522222222, Digit Strip=FALSE
Calling Number=sip:11111111@shims.starhub.net.sg;user=phone(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=+6522222222(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=
Account Number=11111111, Final Destination Flag=TRUE,
Guid=65A8F144-B710-11E7-B6E2-9DB4F6C298A0, Outgoing Dial-peer=20
*Oct 23 18:04:31.106: //797107/65A8F144B6E2/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=+6522222222
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Oct 23 18:04:31.106: //797107/65A8F144B6E2/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x7FF5F247E9C8, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=sip:11111111@shims.starhub.net.sg;user=phone,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=+6522222222(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Oct 23 18:04:31.106: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 23 18:04:31.106: :cc_get_feature_vsa malloc success
*Oct 23 18:04:31.106: cc_get_feature_vsa count is 20
*Oct 23 18:04:31.106: :FEATURE_VSA attributes are: feature_name:0,feature_time:140694386400076,feature_id:35320
*Oct 23 18:04:31.106: //797107/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 23 18:04:31.106: cc_api_get_xcode_stream : 4983
*Oct 23 18:04:31.106: //797107/65A8F144B6E2/CCAPI/cc_api_event_indication:
Event=101, Call Id=797107
Event Is Sent To Conferenced SPI(s) Directly
*Oct 23 18:04:31.106: //797108/65A8F144B6E2/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*Oct 23 18:04:31.106: //797108/65A8F144B6E2/CCAPI/ccCallSetContext:
Context=0x7FF5FB692DF0
*Oct 23 18:04:31.106: //797107/65A8F144B6E2/CCAPI/ccSaveDialpeerTag:
*Oct 23 18:04:31.107: //797108/65A8F144B6E2/CCAPI/ccGetMediaClassTag:
media class tag 0
*Oct 23 18:04:31.107: //797108/65A8F144B6E2/CCAPI/ccSetMediaclassIp2ipTags:
media class tags set: NR 0, ASP 0
*Oct 23 18:04:31.107: //797107/65A8F144B6E2/CCAPI/ccGetMediaClassTag:
media class tag 0
*Oct 23 18:04:31.107: //797107/65A8F144B6E2/CCAPI/ccSetMediaclassIp2ipTags:
*Oct 23 18:04:31.107: //797108/65A8F144B6E2/CCAPI/ccGet_xc_nr_asp_info:
media class tags: NR 0, ASP 0
*Oct 23 18:04:31.107: //797107/65A8F144B6E2/CCAPI/ccGet_xc_nr_asp_info:
*Oct 23 18:04:31.107: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 797107
*Oct 23 18:04:31.107: //797108/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 23 18:04:31.107: cc_api_get_xcode_stream : 4983
*Oct 23 18:04:31.107: //797108/65A8F144B6E2/CCAPI/cc_api_call_proceeding:
Interface=0x7FF5F247E9C8, Progress Indication=NULL(0)
*Oct 23 18:04:31.108: //797108/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 23 18:04:31.108: cc_api_get_xcode_stream : 4983
*Oct 23 18:04:31.108: //797107/65A8F144B6E2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 23 Oct 2017 18:04:31 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.5.3.S4b
Content-Length: 0
*Oct 23 18:04:31.109: //797108/65A8F144B6E2/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:+6522222222@10.15.1.13:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.135.1:5060;branch=z9hG4bKD99F5A4
Remote-Party-ID: "11111111" <sip:11111111@shims.starhub.net.sg>;party=calling;screen=no;privacy=off
From: "11111111" <sip:11111111@172.31.119.249>;tag=E46997F1-1FAA
To: <sip:+6522222222@10.15.1.13>
Call-ID: 65A9B4C2-B71011E7-B6E89DB4-F6C298A0@shims.starhub.net.sg
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 600
Cisco-Guid: 1705570628-3071283687-3068304820-4139948192
User-Agent: Cisco-SIPGateway/IOS-15.5.3.S4b
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1508753071
Contact: <sip:11111111@192.168.135.1:5060>
Expires: 180
Max-Forwards: 64
Cisco-Gcid: 65A9189B-B710-11E7-B6E5-9DB4F6C298A0
Content-Disposition: session;handling=required
Content-Length: 320
v=0
o=CiscoSystemsSIP-GW-UserAgent 954 1748 IN IP4 192.168.135.1
s=SIP Call
c=IN IP4 192.168.135.1
t=0 0
m=audio 40172 RTP/AVP 8 0 18 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
10-23-2017 07:44 AM
Hi Gregory,
I have run the debug and below is the log i got. Calling number is external(11111111) and called number is internal(22222222) and forward the call to external (33333333).
When i call form internal -> internal -> forward to external got no issues ..
But when i call from external -> internal -> forward to external , the phone only ring for 2s and got cut off.
Received:
CSeq: 1 INVITE
Max-Forwards: 65
Min-SE: 600
Content-Length: 222
v=0
s=SBC call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:97 0-15
a=ptime:20
a=sendrecv
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Set Up Event Sent;
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=+6522222222
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
media class tag 0
media class tag 0
Call Id 797107
Sent:
SIP/2.0 100 Trying
CSeq: 1 INVITE
Content-Length: 0
Sent:
Min-SE: 600
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 64
Content-Length: 320
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
10-23-2017 05:29 PM
I see your invite with SDP and your 100 trying I never see the forward attempted to your 33333333 number?
Can you post a sanitized version of your configs?
