Call from number start with 8 &9 is routing out on VG.
When dialing to those numbers that starts with 8 and 9, the call is not reachable and show as engage from my side.
Numbers as follows:
03-8xxxxxxx
03-9xxxxxxx
Need expertise advise on this issue.
Rhuban,
There are a few things wrong with your config...
1. You dont have an inbound voip dial-peer, hence your inbound call leg is matching on dial-peer 0 which by default uses G729, while your outbound call leg is matching on dial-peer 1 which is configured for g711. To resolve this do the ff:
dial-peer voice 10 voip
incoming called number .
dtmf-relay h24-alpha
codec g711ula
no vad
2. The second issue is that the outbound dial-peer that is matched does not have the right destination-pattern
dial-peer voice 1 voip
 destination-pattern 9888
The called number is 988869500
You need to change your dial-peer one to something like
 destination-pattern 9888.....
Please rate all useful posts
Ayodeji Okanlawon
Can you send a debug voip ccapi inout and debug isdn q931
Hi Ayodeji,
Attached is the debug for the number that dropping the call.
Number : 988869500
Rhuban,
codec g711ula
no vad
Hi Ayodeji
Thanks for your prompt response. Really appreciate it. Will try as suggested and let u know the outcome.
