Call from PSTN
MarcoM
Hi all,
when receive a call from PSTN to the extension 30 (for example) call redirect always to extension 20 and I can not call directly to internal numbers.
can anyone help me please?
In attach most important parts of the configuration.
Thanks in advance.
Debug "debug isdn q931":
May 27 17:19:16.557: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x002E
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9838D
                Exclusive, Channel 13
        Calling Party Number i = 0x00A3, N/A
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0xA1, '331234530'
                Plan:ISDN, Type:National
May 27 17:19:16.557: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x802E callID = 0x048E switch = primary-net5 interface = User
May 27 17:19:16.565: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x802E
May 27 17:19:16.565: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x802E
        Progress Ind i = 0x8188 - In-band info or appropriate now available
May 27 17:19:26.513: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x002E
        Cause i = 0x8090 - Normal call clearing
        Progress Ind i = 0x8088 - In-band info or appropriate now available
May 27 17:19:26.513: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x802E
May 27 17:19:26.569: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x002E
20 Replies 20
I dont understand. You said you are calling from outside. That is you are dialling externally this number from outside. SO what do you mean by you cant call external number
0331754535
The trace I looked at..
calling number is 2511403
called number is 3317545
are you saying called number should be 331754535?
Please rate all useful posts
Right..called number should be 331754535 but when dial digits on my personal phone 3+3+1+7+5+4+5 start call...
but I have not finished entering the number 35.
Is your personal phone a mobile?. I am not sure why this is happening..you need to find out if you are dialling the correct number? Or is your personal phone on the ccme router?
Is an analogic phone (home).
With mobile phone if dial number 331754535 and then I start the call reach the desired extension but from analogic phone dont work...
So your system does not have any problem then. Its working. The problem is with your home phone. This forum cant help you with this. The analogic phone is not cisco phone. You need to contact the vendor for the phone...
Pls rate all useful posts
Thanks a lot....
