By doing so you are alternating between the Standard Greeting and the Closed Greeting setting on the Call Handler. You might want to make sure that you do not have any other greeting activated. Make sure you do not have the alternate greeting enabled accident.
Another way to do it is create multiple AA's and use TOD routing in call manager if you are running call manager.
