06-20-2018 12:50 AM - edited 03-17-2019 01:03 PM
HI all,
I am using 8841 ip phone and cucm version 10.5.
8841 model phone is not showing call history option.
if I press application button, I am not seeing recents option to select.
current phone firmware version is 11.7
06-20-2018 02:09 AM
Follow below steps
1- Make sure that the phone configuration is correct. Go to settings on the phone and check the network configuration. Compare the settings with a working phone and make sure that the TFTP etc are correct.
2- Login to the switch where the phone is connected to and verify the Switch Port configuration with the working phone's port.
Kindly rate all helpful posts !!!
06-20-2018 05:21 AM
Hi there
Please try enabling Alternate TFTP on the phones and set a valid TFTP IP address or add an option 150 or 66 TFTP server on the DHCP server's scope for the subnet of the phones
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
