Highlighted
Beginner
Call history on 8900 series with CME
I have a strange problem with one phone in our company.
We're running CME v8 on 2921 router and have a couple of 8961 phones.
When I go to "Applications" and select "Call History", I'm able to see call history on all the phone except one(it shows nothing).
The only difference between this phone and all the other is that he has 2 lines.
One personnal line (1st button) and one shared line with overlay (2nd button).
Anybody have an idea ?
Thx
Fabian
1 ACCEPTED SOLUTION
Highlighted
Advocate
Fabian,
Looks like you are hitting this bug
CSCtn41751 Bug Details
Number of missed calls does not increase
Symptom:
The number of missed calls on phone UI may not increase.
Missed call is not logged
Symptom: One phone makes call to the phone under test, after the caller canceling the call, the phone flashed the missed call icon on session button, then the icon disappears. The phone comes to idle, but no missed call is logged. Conditions: Workaround:
Conditions:
A lots of call history logs are created on phone.
Workaround:
1. Clear the call history.
2. Reset the phone.
This was first found in Ver 9.2.1
There is no published upgrade FW Version so far.
Alex
Regards, Alex. Please rate useful posts.
6 REPLIES 6
Highlighted
Advocate
Fabian
What is your firmware version.
There seems to be a few bugs with call history for these phones.
Alex
Highlighted
Hall of Fame Community Legend
Re: Call history on 8900 series with CME
Hi Fabian,
Just to add a note to the good tips from Alex (+5 my friend!)
You may be seeing this behavior;
missed-calls
To report missed calls to directory numbers on an IP phone, use the missed-calls command in ephone configuration mode. To suppress missed-calls reporting, use the no form of this command.
missed-calls [all]
no missed-calls
Syntax Description
all
(Optional) Displays all missed calls including those on overlay buttons.
Command Default
Missed calls are presented on the IP phone and listed in the missed-calls directory. Missed calls to overlay buttons are not reported.
Command Modes
Ephone configuration (config-ephone)
Command History
Cisco IOS Release
Cisco Product
Modification
12.4(15)XZ
Cisco Unified CME 4.3
This command was introduced.
12.4(20)T
Cisco Unified CME 7.0
This command was integrated into Cisco IOS Release 12.4(20)T.
Usage Guidelines
This command enables Cisco Unified CME to report missed calls on the specified phone. Use the all keyword to report missed calls to overlaid directory numbers. Only calls to an overlay set that are visibly presented on the phone are reported as missed calls. Calls to an overlay that are terminated by the caller before they are displayed on the phone are not reported as missed calls.
If the unique extension number for a phone is assigned to an overlay set on the phone, missed calls to that extension number are not reported unless you enable this command using the all keyword.
Examples
The following example shows that all unanswered calls to 4001 are reported on phone 1.
ephone-dn  1  dual-line
number 4001
ephone  1
mac-address 0014.6AAC.24E3
type 7960
button  1o1,30,31 2:2 3:3
missed-calls all
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_m1ht.html#wp1043550
Cheers!
Rob
Highlighted
Beginner
Alex,
Firmware is : sip8961.9-2-1
Rob,
I think the command you mentionned is only available for SCCP Phones, so not usefull here unfortunately.
I also tried to reset all the settings on the device, but no help.
Fabian
Highlighted
Advocate
Fabian,
Symptom:
Conditions:
Workaround:
2. Reset the phone.
Alex
Highlighted
Hi Fabian,
Just to clarify, I was really only pointing to this note
in the reference which probably applies to both sip or sccp phones
Cheers!
Rob
Beginner
Thank you Alex, that did the trick.
Waiting for next firmware to correct that now
No prob rob, I appreciate it. Just notice that it could not resolve my issue, but good to know.
Thx
Fabian
Content for Community-Ad
FusionCharts will render here
