11-28-2013 12:19 AM - edited 03-16-2019 08:37 PM
Hi all,
I am using CUBE as SIP gateway. When i run "show call active voice brief" command, all the calls have the same call id 1 or 0. So it is hard to track calls at the gateway. Is it normal? Does anybody know the reason of that?
12-07-2013 11:04 AM
Please, add an example of the output of the command.
Regards.
12-07-2013 12:07 PM
Hi.
If you are using sip-ua to connect to a TSP, you can use show sip-ua calls brief
Carlo
Please rate all helpful posts
"The more you help the more you learn"
12-09-2013 02:40 AM
Hi Carlo,
How can i see the dial-peers used for the call if i use "show sip-ua calls brief"?
Safak
12-09-2013 09:14 AM
You can see used SP with show voice call status.
12-08-2013 11:38 PM
Sample output:
0 : 69572 09:34:05.177 Turkey Mon Dec 9 2013.1 +5300 pid:1 Answer XXXX active
dur 00:00:03 tx:169/27040 rx:166/26560
IP
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long duration call duration:n/a timestamp:n/a
0 : 69573 09:34:05.187 Turkey Mon Dec 9 2013.1 +5290 pid:106 Originate XXXXXXXXXXX active
dur 00:00:03 tx:167/26720 rx:170/27200
IP
12-09-2013 02:35 AM
Here is another sample output from another sip gateway(this is not CUBE, it is AS5400)
0 : 360645 12:32:18.042 Turkey Mon Dec 9 2013.1 +5800 pid:1 Answer XXXX active
dur 00:00:17 tx:1/160 rx:870/139200
IP
0 : 360646 12:32:18.094 Turkey Mon Dec 9 2013.1 +5750 pid:106 Originate XXXXXXXXXXX active
dur 00:00:17 tx:871/146328 rx:259/41122
Tele 7/1:D (360646) [7/1.1] tx:17430/3560/0ms g711ulaw noise:-66 acom:45 i/0:-66/-42 dBm
12-09-2013 09:15 AM
I've some AS5400 but I see call ID without problem. Do you have the same IOS version on boot AS and CUBE?
12-09-2013 11:24 PM
I have IOS version of 15.1(4)M6 on AS5400 and 15.1(4)M4 on CUBE(3925)
12-10-2013 03:08 AM
Incoming calls are generated from a CUCM?
12-10-2013 04:10 AM
Yes, calls are generated from CUCM. When we generate the call from PSTN we get a usual call ID for the call legs. Additionallay, not only null, i also see 1 as the call id when the call is generated from CUCM:
From 3925:
1 : 77849 13:55:21.747 Turkey Tue Dec 10 2013.1 +14450 pid:1 Answer XXXX active
dur 00:00:20 tx:1045/167200 rx:1043/166880
IP
1 : 77850 13:55:21.747 Turkey Tue Dec 10 2013.2 +14450 pid:106 Originate XXXXXXXXXXX active
dur 00:00:20 tx:1043/166880 rx:1045/167200
IP
From AS5400:
1 : 378233 14:03:39.836 Turkey Tue Dec 10 2013.1 +8060 pid:5 Answer XXXX active
dur 00:00:19 tx:1/160 rx:982/157120
IP 10.45.100.64:17584 SRTP: off rtt:0ms pl:13840/0ms lost:0/0/0 delay:55/55/65ms g711ulaw TextRelay: off
1 : 378234 14:03:39.884 Turkey Tue Dec 10 2013.1 +8010 pid:106 Originate XXXXXXXXXXX active
dur 00:00:19 tx:983/165144 rx:291/46242
Tele 7/3:D (378234) [7/3.2] tx:19680/4200/0ms g711ulaw noise:-68 acom:45 i/0:-67/-32 dBm
I couldn't find out what causes this.
