03-04-2014 10:07 AM - edited 03-16-2019 10:00 PM
my setup is
PSTN --- GW --- CUCM --- 6921 phone
when we call from the PSTN then call rings and shows connected on the PSTN phone after about 10 sec the call disconnects with fast busy but the 4 digit plar does not ring at all, outgoing calls are working fine. Need help in resolving this issue
Shabbar
03-04-2014 10:15 AM
Please post your GW configuration and describe your CUCM setup.
Yosh
03-04-2014 10:28 AM
03-04-2014 10:56 AM
How you have your FXO configured in CUCM. Can you post a "debug isdn q931"?
Yosh
03-04-2014 11:06 AM
FXO is configured as loop start as below, cannot run the debug isdn
R_SCI_KQ#debug isdn q931
% Invalid input detected at '^' marker.
Registration | Registered with Cisco Unified Communications Manager 192.168.0.26 |
IP Address | 192.168.100.6 |
AALN/S0/SU0/0@R_SCI_KQ.sciafrica.net | |
03-04-2014 11:09 AM
I'm sorry I was thinking about something else when I asked for the "debug isdn q931" you don't have any PRIs.
Yosh
03-04-2014 11:09 AM
Hi.
Being an FXO it supposed to be connected to an analogue line not ISDN :)
a debug vpm all would be useful.
Please activate it , make an inbound call an please post the result
Carlo
03-04-2014 11:14 AM
03-04-2014 11:36 AM
03-04-2014 11:47 AM
Hi Shabbar.
On the vg remove plar config and fill the attendant dn field on port configuration on CUCM with desired destination.
Carlo
03-05-2014 07:58 AM
Removed the plar but still the same behaviour
03-05-2014 08:01 AM
Hi.
Did you configured the attendant DN on port configuration page on CUCM?
If yes, can you check the incoming CSS on the same configuration page?
Let me know
Carlo
Please rate all helpful posts
"The more you help the more you learn"
