Call issues With SIP Trunk
anishgupta86
I am having outbound call failures for 13XXXX numbers, rest all calls work fine. Everything seems fine not sure why the call is failing. Attached is the copy of gateway config. Also attached are the sip debugs. Please Help.
Thanks!!
Seems that you are sending wrong called number to ITSP as they aren't able to route it. Make sure that you format the called number as required by your ITSP. Below for reference
Sent:
INVITE sip:132233@eel.com.au:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.10.125:5060;branch=z9hG4bK41B96449Remote-Party-ID: "DARWIN TBC TEST" <sip:+61292031134@eel.com.au>;party=calling;screen=yes;privacy=offFrom: "DARWIN TBC TEST" <sip:+61292031134@eel.com.au>;tag=465C0F5C-201CTo: <sip:132233@eel.com.au>Date: Sun, 01 Oct 2017 22:09:57 GMTCall-ID: 18105AFC-A62C11E7-9218E0D6-7D12F572@10.10.10.125Supported: 100rel,timer,resource-priority,replaces,sdp-anatMin-SE: 1800Cisco-Guid: 2499364480-0000065536-0000007447-0539535552User-Agent: Cisco-SIPGateway/IOS-15.4.2.TAllow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTERCSeq: 101 INVITETimestamp: 1506895797Contact: <sip:+61292031134@10.10.10.125:5060>Expires: 300Allow-Events: telephone-eventMax-Forwards: 69Session-Expires: 1800Content-Type: application/sdpContent-Disposition: session;handling=requiredContent-Length: 318v=0o=CiscoSystemsSIP-GW-UserAgent 6459 4496 IN IP4 10.10.10.125s=SIP Callc=IN IP4 10.10.10.125t=0 0m=audio 25982 RTP/AVP 0 8 18 101c=IN IP4 10.10.10.125a=rtpmap:0 PCMU/8000a=rtpmap:8 PCMA/8000a=rtpmap:18 G729/8000a=fmtp:18 annexb=noa=rtpmap:101 telephone-event/8000a=fmtp:101 0-15a=ptime:20
*Oct 2 09:09:57.070 EDT: //-1/xxxxxxxxxxxx/SIP/Error/get_content_length:
Could not get Content-length
*Oct 2 09:09:57.070 EDT: //113886/94F946800000/SIP/Msg/ccsipDisplayMsg:
Received:
IP/2.0 100 Trying
Via: SIP/2.0/UDP 10.10.10.125:5060;branch=z9hG4bK41B96449From: "DARWIN TBC TEST" <sip:+61292031134@eel.com.au>;tag=465C0F5C-201CTo: <sip:132233@eel.com.au>Call-ID: 18105AFC-A62C11E7-9218E0D6-7D12F572@10.10.10.125CSeq: 101 INVITETimestamp: 1506895797
Received:
SIP/2.0 404 Not found
Via: SIP/2.0/UDP 10.10.10.125:5060;branch=z9hG4bK41B96449From: "DARWIN TBC TEST" <sip:+61292031134@eel.com.au>;tag=465C0F5C-201CTo: <sip:132233@eel.com.au>;tag=254575448-1506897557634Call-ID: 18105AFC-A62C11E7-9218E0D6-7D12F572@10.10.10.125CSeq: 101 INVITETimestamp: 1506895797Content-Length: 0
Sent:
Received:
IP/2.0 100 Trying
Received:
Spoiler
Hi Mohammed,
I checked for other sites and the number format is the same. However, I have opnened a case with Service Provider to let us know the reason for 404 message.
Thanks!!
Thx for updates. Keep the thread posted and remember to rate useful posts
