Call logs (missed, place, received calls) are not displaying.
waqas sardar
In my company there are two buildings on the same LAN. We have two types of Cisco Ip phones 7965 and 6941.In the first building both types of phones are working fine, but problem is in the second building IP phone 7965 call logs (missed, place, received calls) are not displaying. There is no firewall only switch between two building.
We had taken few steps:
1) Change the IP Phone
2) Delete and reconfigured Ip phone.
But problem is still there. Anyone can tell me the solution?
Regars,
Waqas
problemchild27
     Just check the building 2 IP Phones are taking the same subnet address as building 1 phones. We had similar issue, and we forced the vlan entry in IP Phone though CDP is enabled, which resolved the problem.
Thank you
     PC
6 Replies 6
paolo bevilacqua
Update phone firmware.
problemchild27
Thank you
     PC
problemchild27 @ IP phone getting different subnet and different vlan because in second building there is sepeate DHCP server and different vlan also,but not getting TFTP IP of both Pub and Sub.
Please explain,if you something about this issue?
Best Regard,
Waqas
HI,
     Are you using anyother switch than Cisco? (To connect the IP Phones)
Thank you
      PC
problemchild27 @ only cisco swithes ..How we can assign TFTP IP addreess to cisco IP PHone 7965 manually.?
In order to set a tftp you need to unlock the ip phone network settings, and manually assign the ip settings. Please refer to the following document:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7975G_7971g-ge_7970g_7965g_7945g/8_0/english/administration/guide/7970set.html#wp1162537
Allan
Please rate helpful posts, thank you.
