12-03-2016 11:59 PM - edited 03-17-2019 08:51 AM
Can someone please advise how to route PSTN number to call attendant, in my scenario I got two main numbers which callers can call to office, i would like to forward one of that number to call attendant but other number straight to Hunt group. Please advise step to step guide as i am new to call manager.
At the moment both numbers going to two different hunt group
12-04-2016 07:24 AM
Hi Hasrat,
Suppose a four digit number 1XXX is the DID that the external caller calls, you need to create a translation pattern 1XXX and in the 'Called Party Transformation Mask' field you can enter the destination number ( like 2XXX, where 2XXX is the hunt pilot number for the hunt group ). You will find the following link useful when configuring Translation patterns
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_5_1/ccmcfg/bccm-851-cm/b03txpat.html
Manish
12-04-2016 07:42 AM
To get it to an AA on Unity Connection you can also build a CTI-RoutePoint and CFA to VM.
12-04-2016 10:39 AM
so can I enter destination number to auto attendant instead of hunt group? in this case do i need to create CTI route?
Hasrat
12-04-2016 05:51 PM
If the DNIS of the incoming call is 1234 built a CTI-RP in CUCM with a DN of 1234 and Call Forward All to Unity Connection then pick up the same value with a matching AutoAttendant in Unity Connection.
