Note: If you have Subscribers, when you change the IP address of the Publisher, you need to edit the LMHOST files in the Subscribers to the new IP address.
The document is correct for version 3.x and 4.x CM server to change the IP Address. You should follow this as I don't think you will find any other documentation for this version of CM on CCO.
Deepak
