01-23-2013 12:22 AM - edited 03-16-2019 03:19 PM
Dear All,
I am running call manager 4.2.
I need to configure the directory for the users manually in the call manager.
Can you pleas gudie me how i can do that.
Will be very grateful.
Malik.
Solved! Go to Solution.
01-23-2013 12:34 AM
Just log in to ccmadmin on the publisher, then go to Users/Global Directory. There you can edit the user details and these are used to populate the directory.
Aaron
01-23-2013 12:58 AM
Interesting!
Maybe you have a third party directory service. Take a look at these in Ccmadmin:
1) System/Enterprise Parameters - Look for the 'directories' URL.
2) If this points at the CUCM hostname or IP address, then browse to the URL with firefox. Post up what it returns - if you see nothing, select 'view source' in firefox.
3) Check a phone configuration page - it will also have a directories URL, so do the same thing with that.
Aaron
01-23-2013 02:37 AM
OK - I think you have several problems!
1) You have no users configured on CUCM - that's why you see non in the users page. Can you try clicking 'Add a User' there and see if it allows you to do so?
2) Your phones may not be able to resolve cisco-3f06b3854. Can you replace the hostname part of the URL in the enterprise parameters page to the IP address of your publisher, and then reset the test phone and have another look at the directories menu?
Aaron
01-23-2013 12:34 AM
Aaron
01-23-2013 12:53 AM
Hi Aaron,
Thanks for your reply.
I have like 400 users with extension numbers configured in the call manager.
But i am not able to configure the directory for the users.
Even when i click on the ip phone and look for the directory i could not find it.
As per for advise when i go to users/gloal directory and click and search for any user i could not see any user there.
I am also attaching the screen shoots for better understanding.
Please gudie me how i can accomplish this task.
will be grateful to you.
Malik
01-23-2013 12:58 AM
Interesting!
Aaron
01-23-2013 01:34 AM
i really appreciate your reponse.
please find attached the screen shoots.
yes i can see the call manager hostname in the URL Directories
but when i browse that url to the browser it showes something like this
I would be grateful if you can have a look at the screen shoots and gudie me how we can fix this issue
thanks a lot
Malik
01-23-2013 01:51 AM
01-23-2013 02:37 AM
Aaron
01-23-2013 02:55 AM
Hi Aaron,
I am really thankful to you.
I will follow the steps which you mentioned i will let you know the results for sure.
Thanks a lot
Malik.
02-10-2013 01:04 AM
Dear Arron yes it worked
thanks a lot
so nice of you
Malik
02-10-2013 01:10 AM
Dear Aaron,
I have another query.
I am running Call Manager ver. 5.1
My Server Details are below:
MCS 7816H3
RAM: 2GB
Hard Drive: 2x160= 320 GB
Can you please tell me how i can migrate my MCS server to UCS C series C220.
I will be very thannkful if you can provide me the steps to follow for a successful migration
Regrads
Malik
02-10-2013 02:27 AM
Hi Malik
That's not related to this thread... and there's no need to cross post. I'll respond to your other thread.
Aaron
02-17-2013 02:13 AM
thanks a lot Aaron.
i was afraid that you might nor see my thread thats why i posted it here.
i have another question i have opened another post
