09-20-2017 01:07 AM - edited 03-17-2019 11:12 AM
Folks,
Is the Call manager ver 4.2 request license to works? and Can anyone please share the iso file to install it?
09-20-2017 01:10 AM
In th call manager 4.x , there used to be Paper licenses which were not installed on Server.
regds,
aman
09-20-2017 01:15 AM
Hi Aman,
What do you mean with Paper License, and that need windows server to install it? I need to install it on VM, and want installer file to set up it.
09-20-2017 01:20 AM
Hi, I thought your query was for IP phone license.
It would be somewhat diffcult to installation file /exe for CCM 4.x.
regds,
aman
09-20-2017 07:09 AM
The license was literally a piece of paper from Cisco saying you had bought x licenses for devices to be used, there was no license that was actually installed in the system for it to work.
That version was never tested on a VM, and it used a special Windows OS, I'm not even sure if that would work.
09-20-2017 07:32 AM
Hi Jaime,
can you share with me the file source to install it on windows server 2012?
09-20-2017 07:36 AM
I do not have the image, I doubt anyone has it after 10 years (plus, it was only delivered on physical media), and I seriously doubt it would install on any standard windows as it required a special windows 2000 version.
