Call Manager 5.0 Event Logs
nprdomingo
Need your help on how I can view the System Event Logs on Cisco CallManager 5.0 which is running on Linux. Unlike on version 4, it can be seen on the normal Windows Event Log. The CUCM hangs that is why it is necessary to view the event logs. Hope you can help on how to do this. Thanks in advance!
Jaime Valencia
You access all those logs thru RTMT in Linux appliances.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Javalenc,
Thanks for the information. I gathered the Logs thru RTMT already.
The problem is, am having a hard time on which specific file shows the Event Log.
