Call Manager 6.1 to 8.6 upgrade
we are planning to upgrade our call manager from 6.1 to 8.6 on the MCS7800 publisher and subscriber servers. can we do the upgrading without compromising the current configurations and also retataining the current unit licences? also, does 8.6 support compatibility with unity connection 2.1 or must this be upgraded also?
Jaime Valencia
Yes, you keep all your configs and DLUs and Node Licenses, you will need a valid feature license for this after the upgrade.
Supported Cisco Unified Communications Manager Upgrades
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp43011
SCCP Compatibility  Matrix: Cisco Unity  Connection, Cisco Unified CM, and Cisco Unified CM Express
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
I'm assuming you've already checked your HW supports 8.6 right??
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Thanks. I am ware of hardware requirements. much appreciated
