Walkthrough Wednesdays
6931
arnold Mumba
Beginner
CALL Manager. Calls can come in, Cannot dial out
                  i have configured a CCM 9.1 System but calls can come in , Cannot dial out what could be the cause
2 ACCEPTED SOLUTIONS
I'm not sure that's CUCM, does the call actually hit the GW??
My guess is you're not sending the call setup to telco's liking.
What does a debug says about the call?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
As you are using SIP GW, you can expand the number using translation rule in GW.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con19
also, you can do Called & Calling party transformations (discard digits, prefix & mask) in Route Pattern & Route List level in CUCM
HTH.
Please rate all the useful posts
//Suresh Please rate all the useful posts.
14 REPLIES 14
Is internal call working? (inside the local network)
If everthing is fine, do a close look on CSS
Selvarathnam Nadar
the internal calls are working its the calling out
Arnold, is you using PSTN for calling out, are you created route pattern, etc.
And what you hear when you try to make a outgoing calls
am using PSTN Calling out i have Router 2921 with a SIP Trunk to the CCM and a ISDN PRI E1 to PSTN .WHEN I TRY TO DIAL AN OUTSIDE number i do get the message " your call canot be precessed consult your operator"
It seems that there are not matching route patterns defined in the CUCM.
Can you please check whether any route patterns are created.
Hi Arnold,
As suggested by Mahmood and Nadar, also check for PArtiton and CSS on IPphone from which u are making calls.
Also, check in Route Pattern for Partiton.
Just to simplify, make Route Pattern, CSS,Partiton as None and check.
regds,
aman
based on the error message, it seems issue with CSS/Partition. Please check the partition of the RP is included in device/line css of the phone
Is the CSS and partition are configured properly?
is this a MGCP or H323 gateway?
is MGCP-GW registered with CUCM?
java
java
iam using a Sip trunk betwwen the CUCM and Cisco Router do i need to create a gatway or the trunk will do the job
iam using the SIP Trunk between the CUCM and Router
Hi, Please make a test call and collect detailed CCM traces from CUCM and debug ccsip message, debug voice ccapi inout & debug isdn q931 from GW with calling number, called number
i have discovered that the callmanager was sending only 4 digits to our Telco instead of 7 am working on it . any procedure to correct this
HTH.
Content for Community-Ad
Spotlight Awards 2021
