Showing results forĀ
Search instead forĀ
Did you mean:Ā
Call manager Common Partition Usage is 89%
HI All,
Who know why the call manager version 8.6 Common Partition Usage is 89%? it's very strange. another Call manager Version 8.5 only 22%?
can anybody tell me why?
thanks.
dsobrinho
Level 9
Level 9
Hi Xianchang Wu,
Did you make some upgrade of version  of CUCM?
If did,most likely the older version was this Partition.
Daniel Sobrinho
Hi Xianchang,
This issue could happen if you have too many log files stored in common partition. The steps to delete those files
I would like you to refer the following url-  https://supportforums.cisco.com/docs/DOC-27965
Thanks and Regards,
Geevarghese
