08-01-2017 07:53 AM - edited 03-17-2019 10:55 AM
08-01-2017 08:44 AM
You'll need to pull the dial plan info from CUCM, and then manually map to what you know are your DID's to find that out, CUCM cannot tell you this.
CUCM only know what it's currently configured.
08-01-2017 08:10 AM
No, CUCM doesn't know if the DN/pattern you have configured is a DID or not, so, there is no way it can tell you that information. That has to be managed offline.
CUCM can tell you what is configured in the route plan report, but it's up to you to filter that and find out which ones are DIDs and which ones aren't.
08-01-2017 08:21 AM
What about if we add a range like 1XXX to 2XXX and query which one is free
08-01-2017 08:44 AM
08-01-2017 11:29 PM
