05-31-2014 05:51 AM - edited 03-16-2019 10:56 PM
We have configured call manager express on the router. We have two kinds of dialling. Any calls to mobile is working fine and sends all 10 digits
however when we dial local number of 8 digits, we are unable to dial. On checking we notice that calls are getting prefixed by 0. This should not happen
So for mobile 10 digits are perfectly going. However calls for 8 digits or 11 digits or international calls are not going through.
We need help
05-31-2014 10:22 AM
post "show run" and let us know what trunk type you are using, i.e. SIP trunk, PRI, FXO, etc? Then we can request proper debug.
Chris
06-01-2014 02:52 AM
Looks like issue may be with Digit Manipulation / Voice Translation but its hard to tell without see your run config
06-01-2014 11:11 PM
Please see the attached Runnig Config
Router#
Router#
Router#
Router#sh run
Building configuration...
Current configuration : 2647 bytes
! Last configuration change at 10:45:06 UTC Tue May 27 2014 by ninesec
version 15.2
hostname Router
boot-start-marker
boot-end-marker
card type e1 0 0
enable secret 5 $1$eLS3$6pHArA2bG8ne2JYZJIAvb/
aaa new-model
--More-- !
aaa session-id common
network-clock-participate wic 0
ip cef
ip dhcp excluded-address 10.87.122.1 10.87.122.10
ip dhcp pool VOICE
network 10.87.122.0 255.255.255.0
default-router 10.87.122.10
option 150 ip 10.87.122.10
no ipv6 cef
--More-- !
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
license udi pid CISCO2901/K9 sn FGL181423P2
hw-module ism 0
hw-module pvdm 0/0
--More-- !
username ninesec privilege 15 secret 5 $1$dN18$I1gmZkecZRYnf4ibKj3kL/
username cisco privilege 15 password 0 cisco
redundancy
controller E1 0/0/0
framing CRC4
pri-group timeslots 1-5
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.87.122.10 255.255.255.0
duplex auto
speed auto
--More-- !
interface ISM0/0
no ip address
shutdown
!Application: CUE Running on ISM
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-4ess
isdn incoming-voice voice
no cdp enable
--More-- interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/cpconfig-29xx.cfg
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
--More-- voice-port 0/1/1
mgcp profile default
dial-peer voice 1 pots
destination-pattern 0T
direct-inward-dial
port 0/0/0:15
gatekeeper
shutdown
telephony-service
max-ephones 30
max-dn 60
--More-- ip source-address 10.87.122.10 port 2000
max-conferences 8 gain -6
web admin system name ninesec password c34ph&co
transfer-system full-consult
ephone 1
line con 0
privilege level 15
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
--More-- no exec
transport input all
stopbits 1
line vty 0 4
privilege level 15
transport input all
scheduler allocate 20000 1000
end
Router#
Router#
Router#
Router#
06-01-2014 11:28 PM
Issue seems to be with this dial peer only. If you dial something which start from 0 (eg 0xxxxxxxxx), then it will remove the 0 automatically. Give "forward-digits all" command under this dial peer as below and then test.
direct-inward-dial
forward-digits all
port 0/0/0:15
Suresh
06-01-2014 11:46 PM
We had inserted the command, Forward-digit all,
all calls stopped working
We changed the Pattern 0.T, it did not work
We have the debug below
debug isdn q931
debug voip ccapi inout
Exclusive, Channel 5
Calling Party Number i = 0x2180, '2400'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '67974078'
*May 31 12:59:17.158: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x80F7
Channel ID i = 0xA98385
*May 31 12:59:29.162: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x80F7
Cause i = 0x829C - Invalid number format (incomplete number)
Progress Ind i = 0x8288 - In-band info or appropriate now available
*May 31 12:59:29.162: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; P
let me know the opinion
06-02-2014 12:16 AM
Calls disconnected bcoz you might be dialing 0 as a access code and then number. Anyway here this seems to be service provider issue, you can ask to service provider to check the same at their end and ask why they are sending "disconnect" message.
Suresh
06-03-2014 12:08 PM
Make another dial peer for 8 digit numbers & Preference or you can use voice translation rule command to manipulate numbers (the way you want them to outbound).
Let me know if you need any further help
06-03-2014 04:15 PM
