753
gsriraman
Beginner
Call Manager Express dial peer issue
We have configured call manager express on the router. We have two kinds of dialling. Any calls to mobile is working fine and sends all 10 digits
however when we dial local number of 8 digits, we are unable to dial. On checking we notice that calls are getting prefixed by 0. This should not happen
So for mobile 10 digits are perfectly going. However calls for 8 digits or 11 digits or international calls are not going through.
We need help
8 REPLIES 8
Chris Deren
Hall of Fame Master
post "show run" and let us know what trunk type you are using, i.e. SIP trunk, PRI, FXO, etc? Then we can request proper debug.
Chris
zahidanwar1
Beginner
Looks like issue may be with Digit Manipulation / Voice Translation but its hard to tell without see your run config
gsriraman
Beginner
Please see the attached Runnig Config
Router#
Router#
Router#
Router#sh run
Building configuration...
Current configuration : 2647 bytes
! Last configuration change at 10:45:06 UTC Tue May 27 2014 by ninesec
version 15.2
hostname Router
boot-start-marker
boot-end-marker
card type e1 0 0
enable secret 5 $1$eLS3$6pHArA2bG8ne2JYZJIAvb/
aaa new-model
 --More--         !
aaa session-id common
network-clock-participate wic 0
ip cef
ip dhcp excluded-address 10.87.122.1 10.87.122.10
ip dhcp pool VOICE
 network 10.87.122.0 255.255.255.0
 default-router 10.87.122.10
 option 150 ip 10.87.122.10
no ipv6 cef
 --More--         !
isdn switch-type primary-net5
voice-card 0
 dspfarm
 dsp services dspfarm
license udi pid CISCO2901/K9 sn FGL181423P2
hw-module ism 0
hw-module pvdm 0/0
 --More--         !
username ninesec privilege 15 secret 5 $1$dN18$I1gmZkecZRYnf4ibKj3kL/
username cisco privilege 15 password 0 cisco
redundancy
controller E1 0/0/0
 framing CRC4
 pri-group timeslots 1-5
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 10.87.122.10 255.255.255.0
 duplex auto
 speed auto
 --More--         !
interface ISM0/0
 no ip address
 shutdown
 !Application: CUE Running on ISM
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface ISM0/1
 description Internal switch interface connected to Internal Service Module
 no ip address
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn switch-type primary-4ess
 isdn incoming-voice voice
 no cdp enable
 --More--         interface Vlan1
 no ip address
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/cpconfig-29xx.cfg
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
 --More--         voice-port 0/1/1
mgcp profile default
dial-peer voice 1 pots
destination-pattern 0T
direct-inward-dial
port 0/0/0:15
gatekeeper
 shutdown
telephony-service
 max-ephones 30
 max-dn 60
 --More--          ip source-address 10.87.122.10 port 2000
 max-conferences 8 gain -6
 web admin system name ninesec password c34ph&co
 transfer-system full-consult
ephone  1
line con 0
 privilege level 15
 logging synchronous
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 67
 --More--          no exec
 transport input all
 stopbits 1
line vty 0 4
 privilege level 15
 transport input all
scheduler allocate 20000 1000
end
Router#
Router#
Router#
Router#
Issue seems to be with this dial peer only. If you dial something which start from 0 (eg 0xxxxxxxxx), then it will remove the 0 automatically. Give "forward-digits all" command under this dial peer as below and then test.
direct-inward-dial
forward-digits all
port 0/0/0:15
Suresh
gsriraman
Beginner
We had inserted the command, Forward-digit all,
all calls stopped  working
We changed the Pattern 0.T, it did not work
We have the debug below
debug isdn q931
debug voip ccapi inout
     Exclusive, Channel 5
        Calling Party Number i = 0x2180, '2400'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '67974078'
*May 31 12:59:17.158: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x80F7
        Channel ID i = 0xA98385
*May 31 12:59:29.162: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80F7
        Cause i = 0x829C - Invalid number format (incomplete number)
        Progress Ind i = 0x8288 - In-band info or appropriate now available
*May 31 12:59:29.162: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; P
let me know the opinion
Calls disconnected bcoz you might be dialing 0 as a access code and then number. Anyway here this seems to be service provider issue, you can ask to service provider to check the same at their end and ask why they are sending "disconnect" message.
Suresh
Make another dial peer for 8 digit numbers & Preference or you can use voice translation rule command to manipulate numbers (the way you want them to outbound).
Let me know if you need any further help
Nadeem Ahmed
Calling Party Number i = 0x2180, '2400' Plan:ISDN, Type:National Called Party Number i = 0xA1, '67974078' You are sending 4 digit clg party number and 8 digit cld party number . You should know what digit you need to send for 8, 10 and 11 digit calling accordingly you can have dial-peer created on cme and calling and called party number can also be manipulated through translation pattern . Br Nadeem
Br, Nadeem Please rate all useful post.
Create
Recognize Your Peers
Content for Community-Ad
