Call Manager Express, Virtual number setting
likewinered
Hi all.
I want create to virtual phone number on CME.
For example, inbound call number is 6000. (This number don't have physical ip phone. Representative number)
If, Can I used call-forward to another phone number?
And, If it can use, Please give me CME config for using.
Thanks.
Jaime Valencia
If all you want is to translate 6000 to something else, just use translation rules
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/64020-number-voice-translation-profiles.html
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/61083-voice-transla-rules.html
java
if this helps, please rate
Thanks for your reply.
Based on your reply, I create config for sample. Verify please.
voice translation-rule 2
rule 2 /^6000$/ /60../
Inbound call 01-2345-6000 (Representative number),
6000 -> 60xx number.
Is this config correct?
Thank you.
It kinda looks OK, but I have no idea of your config or what routing you want, whether it will work or not, that's up to whatever you have configured and how you want your routing to work.
You usually set it directly to other DN (ie 6001), either a pilot, or something like that. Again, that's completely up to your config.
java
