07-30-2012 01:31 PM - edited 03-16-2019 12:26 PM
I am installing Call Manager in a test environment which is located on a separate VLAN as our current production. My question is whether phones will automatically register with test environment once it is online? For example, we can ping between the VLANs and it is what we are afraid of.
07-30-2012 01:48 PM
in the dhcp for your test vlan assing the ip 150 option the tftp address of the cucm test
for second question.... depends by your network design
07-30-2012 02:45 PM
The test Pub/Sub is setup in a VLAN that is not an auxiliary (voice) VLAN and no option 150 TFTP has been configured on it. I believe this will not cause production phones to attempt to register with the test servers. Any thoughts?
07-30-2012 03:00 PM
put the phones on the vlan with different network compared to production, the and configure the dhcp for this different network you do not be afraid
the production phones are in other vlan with other dhcp scope, it's possible that the 2 networks are be able to communicate but is not problem.
there is no impact if you make changes to CUCM of tes, you have two separate systems
07-30-2012 05:37 PM
Phones will only auto-register/register given these conditions (ALL of them):
A) They are either manually configured or via DHCP to get the IP/mask/default GW and TFTP server (pointing to your TFTP)
B) There is full connectivitty between phones and CUCM/TFTP servers
C) You have auto-registration enabled on the server you're pointing the phones or CUCM already has that phone configured.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
