03-30-2015 08:51 AM - edited 03-17-2019 02:29 AM
Someone in our HQ is logging into our Call Managers. I need to figure how to trace whom it is.
Any idea's how I can do this?
03-30-2015 08:54 AM
Depending on your version of CUCM, you can review the audit logs, or in case you don't have the option, tomcat traces, this has been discussed several times before on CSC, you can find further info on previous threads.
04-18-2015 11:37 AM
Hi parden,
You can also run : set logging enable
in CUCM Cli mode this will atleast allows you to enable CLI Admin logs
and to check all the logins detail run : show logins
Spooster
