ā11-10-2011 06:28 PM - edited ā03-16-2019 08:00 AM
Running callmanager 7.1.5 with unity connection. Callers hit a call handler and dial an extension. The extension rings 30 times then the call drops. Don't ask why the call rings 30 times!! Is there a place in callmanager where the maximum number or rings are defined? I looked in service parameters and did not see anything.
Solved! Go to Solution.
ā11-10-2011 07:55 PM
What exactly do you want the behavior to be? 30 would mean the phone was ringing for at least 2 minutes, maybe as much as 2 1/2. How long should it ring?
For what it's worth, it's the T301 timer that's causing the call to terminate after 30 rings, but it's actually based on a number of milliseconds. Default value is 180 seconds.
Cliff
please rate helpful posts
Cliff
ā11-10-2011 08:33 PM
Thanks I know it sounds wierd but I want it to ring until the person calling gives up but it set it to the max 900 seconds. That should do it.
