call manager not accepting unknown callers from outside
carl_townshend
Hi There
We seem to have an issue with one of our call manager systems on 4.1
The system doesnt seem to accept any calls coming from outside if the number has now cli, basically any withheld number.
How do we get the system to allow this ?
cheers
Carl
acampbell
Carl,
1) What is your telco line connection PRI BRI FXO SIP etc ?
2) What kind of gateway are you running H323 MGCP SIP ?
3) Do you control your calls via translation patterns on CUCM or in your IOS ?
May be you could answer these questions and provide any router configs or CUCM info etc.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
its a PRI with a H323 gateway,
I can only see 1 translation pattern on the system, it says called party transfor mask 1900
thats all I can see on CUCM
I have checked the H323 gateway and I can see this
voice translation-rule 1
rule 1 /^0\([4-8]..\)/ /\1/
voice translation-profile ENTRADA-LOCAL-DDR
translate called 1
voice-port 0/0/0:0
translation-profile incoming ENTRADA-LOCAL-DDR
cptone BR
any ideas ?
Carl,
Can you show the full router config ?
Alex.
