08-21-2012 01:28 AM - edited 03-16-2019 12:47 PM
Hi There
We seem to have an issue with one of our call manager systems on 4.1
The system doesnt seem to accept any calls coming from outside if the number has now cli, basically any withheld number.
How do we get the system to allow this ?
cheers
Carl
08-21-2012 03:11 AM
Carl,
1) What is your telco line connection PRI BRI FXO SIP etc ?
2) What kind of gateway are you running H323 MGCP SIP ?
3) Do you control your calls via translation patterns on CUCM or in your IOS ?
May be you could answer these questions and provide any router configs or CUCM info etc.
Alex.
Please rate useful posts.
08-21-2012 07:27 AM
its a PRI with a H323 gateway,
I can only see 1 translation pattern on the system, it says called party transfor mask 1900
thats all I can see on CUCM
I have checked the H323 gateway and I can see this
voice translation-rule 1
rule 1 /^0\([4-8]..\)/ /\1/
voice translation-profile ENTRADA-LOCAL-DDR
translate called 1
voice-port 0/0/0:0
translation-profile incoming ENTRADA-LOCAL-DDR
cptone BR
any ideas ?
08-21-2012 09:09 AM
Carl,
Can you show the full router config ?
Alex.
