09-02-2015 01:42 AM - edited 03-17-2019 04:11 AM
We have a SIP trunk between Call Manager and Sonus Gateway (SBC 1000) to office365 voice mail.
The issue is that Call Manager send to Sonus a SIP CANCEL.We have reviewed the SIP trunk configuration on both devices and is the same that always. This voice mail feature fails since the certificates on Sonus were updated.
We attach the call flow,
09-02-2015 02:19 AM
Don't you expect reply of INVITE from Sonus?
Since there is no reply, CUCM is forced to clear the transaction using CANCEL.
You need to look at Sonus side why it's not replying for SIP INVITE.
09-02-2015 08:34 AM
09-02-2015 11:38 AM
This is normal behavior as by default, CUCM uses SIP delayed offer and hence you are not seeing SDP offer in initial INVITE message.
If Sonus doesn't want to see initial INVITE without SDP, it should not have hold the call for long. Anyway, if you're not sure what's wrong at Sonus side, try enabling early offer in CUCM (under SIP Profile).
09-03-2015 03:38 AM
09-03-2015 03:58 AM
Please see my earlier post. Something wrong with you SBC.
09-04-2015 01:40 AM
I have seen that Sonus not send the calling to UM 365.
SBC gives the following error related to invalid destination IP:
<135>[2015-09-01 16:30:33,393] 3400 0001 com.sonus.sbc.sip DEBUG (Transaction.cpp:645) - createClientTransaction: Transaction destination is XX-XX-XX-XXX.um.outlook.com [0.0.0.0]:5061
<131>[2015-09-01 16:30:33,393] 3401 0001 com.sonus.sbc.sip ERROR (Transaction.cpp:648) - createClientTransaction: Transaction Invalid dest. IP
Anybody knows how create a direct SIP trunk between CM and UM 365 without SIP trun with Sonus SBC?
Thanks in advance!
09-04-2015 02:07 AM
Ok, so as expected SBC was having problem. Do you mean by UM 365 as Office 365?
If that is the case you need aSBC. Microsoft office365 dont support integration with Cisco CUCM
09-03-2015 04:02 AM
Although INVITE is still going without SDP but I doubt there is anything wrong in CUCM. You need to check the logs/debugs in Sonus what's going wrong there.
09-02-2015 12:10 PM
The CANCEL is sent with cause value of 102. This means that CUCM INVITE timer expired without response from Sonus.
You need to check if Sonus is sending the call to outside and whether Sonus is receiving a response or not because Sonus isn't indicating to CUCM that the call is answered. Sonus is sending TRYING to CUCM which means the Sonus is trying to send the call to outside but no further messages. Then the timer is expired and CUCM cancels the call.
