12-30-2014 08:36 AM - edited 03-17-2019 01:27 AM
Hi Expert,
if call manager subscriber is down what will be happen active call on the subscriber drop or not ?
Can you please explain this for me.
The another question
if call manager is down what will be conference calls?
Thanks and Regards
Kemal,
12-30-2014 10:56 AM
Assuming you're not using the MTP for the call, no, they won't drop, RTP is directly between endpoints.
Your conference question depends on your MRGL config and how many CFB you have. I recommend you read the media resources chapter from CUCM system guide.
12-31-2014 01:43 AM
I think if subscriber goes down active call will drop on the subscirber coz SIP/h323 controlling by registered subsciber.
ıf publisher goes down there are no problem but subsciber goes down active call will drop.
If i have mistake please correct me.
12-31-2014 02:13 AM
I am sorry your thinking is a little wrong. I have explained how sip/h323 is different from mgcp. Please read my post again.
12-31-2014 02:21 AM
Im not mention mgcp ,I ask only in t his senerio: if phone A cals to phone b or phone Acalls to outbound pstn number while call is talking state sbscirber goes down what will happen ?
12-30-2014 01:18 PM
In addition calls to/from PSTN would depend on 2 factors: what voip protocol is used to control the GW and what type of PSTN circuit you are using, with SIP/H323 generally call would stay up, with MGCP PRI for example it would not.
12-31-2014 12:11 AM
Hi Chris,
the active call in SIP/H323 PSTN gateways will be dropped in case of failover. In MGCP PSTN gateway the call will be connected in failover situation
Anas
01-01-2015 02:25 AM
Anas
I am sorry you are wrong here. With sip and h323, cucm is involved only at the signaling phase once signaling is completed, media flows between the endpoints. However for MGCP, the gateway is always controlled by cucm hence when the subscriber the gateway is registered to goes down, the D channel drops thereby dropping the call.
Here is the question again..
"if call manager subscriber is down what will be happen active call on the subscriber drop or not"
Question to you is..is Subscriber Involved in an active call? Is media terminated on cucm?
01-01-2015 02:25 AM
For MGCP I tested several Time and it is working.
when you have PRI registered as MGCP and you have failover scenario it works perfectly the call is not dropped.
In H323/SIP it will drop the call in case of switchover
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cminterop/configuration/15-mt/dia-15-mt-book/vc-ucm-mgcp-gw.html#GUID-4EBCAC81-B895-4BF3-8A1D-A453FD820641
Anas
01-01-2015 04:06 AM
Anas,
This thread is not about switchover to srst. This thread is about media preservation when your active subscriber fails. For mgcp media can be preserved only if you have a backup cucm. For sip/h323 media is not anchored on cucm so it has no impact.
For srst you can use the call preserve feature to keep our active connection during switch over. This is well documented.
