Call Manager Upgrade from 8.6 to 10.5 fails
kwaldecker
Hello there
I am upgrading a customer from 8.6.2.24901-1 to 10.5
each time the upgrade fails and shows no inactive partition (obviously since the upgrade failed)
I tried upgrading to 10.5.2.11900-3 and 10.5.2.10000-5 both with the same results.
I will attach the install log to the post.
More detail on the steps taken.
loaded new version of 8.6 on UCS server and restored the call manager database
installed the version3-keys.cop file and then tried the upgrade which fails.
I also completely reloaded the steps above and tried to upgrade to the latest 8.6.2.25900-8 but after that upgrade the server would no longer boot :/
I have had a tac case open for a week on it with no luck so far.  they had me delete a SIP conference phone profile and try the upgrade again.  nothing changed
anyone see anything in the logs that might help?  i can't decipher them :P
23 Replies 23
Disable auto registration by going to System - Cisco Unified CM Group Configuration
Also attached is screenshot
Jitender Bhandari
PCD - > Cisco Prime Collaboration Deployment explained below.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/pcdadmin/10_0_1/CUCM_BK_U9C58CB1_00_pcd-administration-guide-1001.html
Jitender Bhandari
+5 for your analysis as well mate :-)
here are the screenshots   nothing looks out of place
I think I have it fixed!
Another engineer on my team helped look at things and he noticed that the upgrade after the Auto registration was turned off actually was timing out.
So he changed the VM to have more ram and 2 processors.  once he did that the upgrade ran fine.  I did the switch version and it came back up.  I am shutting it down to make some changes and booting back up.
thanks again for everyones help!
I bet it worked after turning off auto-registration, i think you dont have to add to RAM and CPU as long as you are using the correct OVA file.
But happy to see we got it working.
Jitender Bhandari
After disabling auto registration the upgrade failed as no enough space was there.  And the CUCM itself freed space on the logging/ common as it was hitting the high water Mark, as this process takes some time,  the upgrade went fine afterwards.
admincoco
Hi.
Don't know if it helps.
I had to upgrade to 8.6.3 before 10.5.
i don't see a 8.63 out there.  i had made a new server to match my existing one and tried the latest 8.6.2 but that made the server unbootable
