05-26-2015 07:41 AM - edited 03-17-2019 03:07 AM
Hello there
I am upgrading a customer from 8.6.2.24901-1 to 10.5
each time the upgrade fails and shows no inactive partition (obviously since the upgrade failed)
I tried upgrading to 10.5.2.11900-3 and 10.5.2.10000-5 both with the same results.
I will attach the install log to the post.
More detail on the steps taken.
loaded new version of 8.6 on UCS server and restored the call manager database
installed the version3-keys.cop file and then tried the upgrade which fails.
I also completely reloaded the steps above and tried to upgrade to the latest 8.6.2.25900-8 but after that upgrade the server would no longer boot :/
I have had a tac case open for a week on it with no luck so far. they had me delete a SIP conference phone profile and try the upgrade again. nothing changed
anyone see anything in the logs that might help? i can't decipher them :P
05-26-2015 12:24 PM
i see the below error in the logs,
05/21/2015 15:55:58 appmanager.sh|Internal Error, File:/usr/local/bin/base_scripts/appmanager.sh:273, Function: refresh_upgrade(), failed to refresh_upgrade infrastructure_post components|<LVL::Critical>
Can you provide me the output of below commands
file get activelog cm/trace/dbl/sdi/installdb/*
file get activelog cm/trace/dbl/sdi/*
file get activelog /cm/trace/dbl/sdi/installdb_ru.log.err
file get activelog /cm/trace/dbl/sdi/installdb_ru*
Jitender Bhandari
05-26-2015 12:38 PM
05-26-2015 01:09 PM
Do you have any dial plan installed on CUCM
05-26-2015 01:40 PM
No dial plan installed. that was the last thing TAC had me check a few hours ago. the numbering plan section in route patterns is greyed out and in the installer section there is nothing listed
05-27-2015 01:22 AM
Hello Guys,
Issue is not related to dial-plans, I checked the logs and it appears something wrong in the auto configuration configurations:
15:55:53.391 | installdb::fixAutoReg select pkid, AutoregistrationStartDN , AutoregistrationEndDN , AutoregistrationNextDN,fkRoutePartition_AutoRegistration,E164MaskAutoregistration,name FROM callmanager where AutoregistrationStartDN <> AutoregistrationEndDN
15:55:53.393 | installdb::fixAutoReg EXECUTE FUNCTION UniversalDeviceTemplate_CreateDefault('10.19.11.83')
15:55:53.400 | installdb::fixAutoReg *ERROR* SQL Exception [0xffffff11] [Error fetching data from datasource: [Informix][Informix ODBC Driver][Informix]Could not insert new row - duplicate value in a UNIQUE INDEX column (Unique Index:assign).]
15:55:53.400 |<--installdb::fixAutoReg
15:55:53.400 | installFull *ERROR* Error Processing fixAutoReg() : Action [RU] , Source DSN [DSN=ccm_b;Servername=morriscm2_ccm10_5_2_10000_5] , Dest DSN [DSN=ccm_super;Servername=morriscm2_ccm10_5_2_10000_5] ,Current status [0]
15:55:53.401 | installFull installFull rc[1]
can you please double-check the auto-rigistartion config and provide screenshot from auto-registration config for all servers?
Thank you,
Shadi
05-27-2015 04:48 AM
Are you talking about the auto registration of phones when they are plugged in without being manually configured? if so what looks wrong?
05-27-2015 05:35 AM
Nice catch Shadi.
I checked the logs again this morning we could see refresh upgrade failing with below error.
15:55:53.375 |<--DBUtil::TableExists
15:55:53.376 | installdb::fixAutoReg update processconfig set paramvalue = 'T' WHERE paramname = 'AutoRegistrationLegacyMode'
15:55:53.385 | installdb::fixAutoReg SELECT FIRST 1 count(fkdevicepool) cnt,fkdevicepool FROM defaults GROUP BY fkdevicepool ORDER BY cnt DESC
15:55:53.387 | installdb::fixAutoReg SELECT FIRST 1 count(NVL(dp.fkcallingsearchspace_autoregistration,'')) cnt,NVL(dp.fkcallingsearchspace_autoregistration,'') css FROM defaults d join devicepool dp on d.fkdevicepool = dp.pkid GROUP BY css ORDER BY cnt DESC
I've got a question
1) are you using PCD
If the answer to above is Yes, we are running into a known issue i would recommend disabling auto registration on any active node on cluster and re-run the upgrade.
Jitender Bhandari
05-27-2015 05:40 AM
what is PCD? not familiar with that acronym
05-27-2015 05:43 AM
Can you try disabling Auto Registration and start the upgrade again?
05-27-2015 05:44 AM
I'm trying it now! thanks for the suggestion. i'll post what happens
05-27-2015 06:43 AM
The upgrade failed again. Any particular logs to look at this time?
05-27-2015 07:48 AM
same logs please.
05-27-2015 08:05 AM
05-27-2015 08:34 AM
different error this time:
Not enough space on partition to proceed|<LVL::Error
Kindly send me the CLI output of "show status" from the server.
