Call Manager with h323 gateway
Lulzim Islami
Hi all,
I’m running CUCM 7.1.5 version with 3825 as a gateway. Currently we are using MGCP in our PRI E1 line. I have users with 7942 phones and their request is to have second number which is DID from FXO port.
I have configured another 2821 router with 4 FXO ports with h323 gateway only for these lines.
With MGCP everything worked correctly except Caller ID issue on FXO, I was able to configure second line and point to prefix DN which in my case was extension 1000.
However, with h323 I’m not able to do a same thing, I’m out of ideas and any help will be appreciated a lot.
Here is scenario:
Phone: 7942 with 2 lines
Line 1 – Ext 1110 (MGCP PRI line for incoming and outgoing calls, Gateway 3825)
Line 2 – Ext 1000 (h323 FXO line for incoming calls, Gateway 2821)
PSTN number is 038541078
I’m trying to map ext 1000 with PSTN number 038541078
interface GigabitEthernet0/0
description Uplink to Core1
ip address 10.117.4.249 255.255.255.252
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.117.4.249
voice-port 0/1/0
supervisory disconnect dualtone mid-call
no battery-reversal
signal groundStart
cptone DE
timeouts call-disconnect 1
timeouts ringing 7
timeouts wait-release 3
timing hookflash-out 50
impedance complex2
caller-id enable
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
dial-peer voice 1 voip
destination-pattern 1000
session target ipv4:10.150.10.2 (CUCM IP ADDRESS)
incoming called-number 1000
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 4 pots
destination-pattern 9T
incoming called-number 038541078
port 0/1/0
forward-digits all
And here is the debug output (debug voip dialpeer)
Nov  2 11:43:32.092: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x49A670E4,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=4
2821Voice#
Nov  2 11:43:50.104: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=9T, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
Have you checked inbound CSS and partitions in CUCM?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
7 Replies 7
Jaime Valencia
Configure a PLAR for it.
connection plar - Use this command to           specify a PLAR connection. PLAR is handled by associating a peer  directly with           an interface. When an interface goes off-hook, the peer is used to set  up the           second call leg and conference them together without the caller having  to dial           any digits. Configure this command at the voice-port configuration  mode.
http://www.cisco.com/en/US/partner/tech/tk1077/technologies_configuration_example09186a00800942a5.shtml
java
java
Hi Javalenc,
One step ahead, now I'm getting CUCM message "your call can not be complited as dialed, please...." when I'm dialing 038541078.
Here is the debug output now:
Nov  2 12:32:01.463: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Nov  2 12:32:01.471: //-1/06C1B5A08135/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1000, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1000
   Result=Success(0) after DP_MATCH_DEST
Nov  2 12:32:01.471: //-1/06C1B5A08135/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=1
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
Nov  2 12:32:01.471: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=1000, Called Number=1000, Peer Info Type=DIALPEER_INFO_SPEECH
Nov  2 12:32:01.471: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
Nov  2 12:32:01.475: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1000, Called Number=, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=1
Nov  2 12:32:01.475: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Nov  2 12:32:01.475: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
Nov  2 12:32:01.475: //-1/06C1B5A08135/DPM/dpMatchPeersCore:
Nov  2 12:32:01.475: //-1/06C1B5A08135/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
Nov  2 12:32:01.499: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=, Peer Info Type=DIALPEER_INFO_SPEECH
2821Voice#No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Nov  2 12:32:01.499: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
2821Voice#
Nov  2 12:32:10.819: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
2821Voice#
Nov  2 12:32:13.823: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
java
java
I deleted the gateway and recreate it again and now it is working.
One more issue, caller ID is not showing up again, and the call is not disconnecting.
I also made chages to cptone but no sucess.
Thanks for the help.
Hi Valdet
Have you enabled the following command in your config?
voice service voip
  h323
  h225 display-ie ccm-compatible
Nicolas
Hi Nicolas
I did enable the command bellow but the issue remains same.
Any sugestions?
Correction.
On my previous reply I said after deleting the gateway and recreating it worked. Wrong step was the Prefix DN on Call Routing Information - Inbound Calls in CUCM. Extension 1000 was assigned in Prefix DN and thats why I was getting message "Your call cannot be complited..."
Since the voice port is set up as a PLAR, it will point the calls straight to the ext 100, and there is no need to be assinged in CUCM.
Anyway, thanks for the help and I'm still having dificulties getting caller ID on FXO with H323.
