153
Highlighted
Beginner
call not going out to carrier.
Dial-peer 200 is set with a session target of our carriers IP.  But for some reason even though call is matching the dial peer the call gets sent to the routers LAN IP.  it doesnt go to the carrier.
dial-peer voice 200 voip
description OUTBOUND Carrier1
max-conn 2
destination-pattern 8889990*[2-9]..[2-9]......
session protocol sipv2
session target ipv4:1.1.1.1
voice-class codec 21
voice-class sip bind control source-interface GigabitEthernet0/0
voice-class sip bind media source-interface GigabitEthernet0/0
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
VoiceGW#
*Oct 12 16:30:41.213: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:8889990*3051234567@10.21.10.250 SIP/2.0
Via: SIP/2.0/UDP 10.21.10.12:5080;rport;branch=z9hG4bKa6g2D4S2UFDtm
Max-Forwards: 69
From: "1001" <sip:FreeSWITCH@10.21.10.250>;tag=a63HpK4ScS0Fp
To: <sip:8889990*3051234567@10.21.10.250>
Call-ID: c09b9f1a-0b3f-1235-41bf-005056820b2e
CSeq: 97809650 INVITE
Contact: <sip:gw+f170dc57-cdf4-4115-933c-7c9b5d4e1fed@10.21.10.12:5080;transport=udp;gw=f170dc57-cdf4-4115-933c-7c9b5d4e1fed>
User-Agent: FreeSWITCH
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, INFO, UPDATE, REGISTER, REFER, NOTIFY
Supported: timer, path, replaces
Allow-Events: talk, hold, conference, refer
Content-Type: application/sdp
Content-Disposition: session
Content-Length: 289
X-accountcode: 10.21.10.12
X-FS-Support: update_display,send_info
Remote-Party-ID: "1001" <sip:13053284888@10.21.10.250>;party=calling;screen=yes;privacy=off
v=0
o=FreeSWITCH 1476263554 1476263555 IN IP4 10.21.10.12
s=FreeSWITCH
c=IN IP4 10.21.10.12
t=0 0
m=audio 27874 RTP/AVP 0 8 3 101 13
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
*Oct 12 16:30:41.213: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=8889990*3051234567, Called Number=8889990*3051234567, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=8889990*3051234567
*Oct 12 16:30:41.213: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=8889990*3051234567, Expanded String=8889990*3051234567, Calling Number=8889990*3051234567T
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
*Oct 12 16:30:41.213: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=200 Is Matched
Result=Success(0) after DP_MATCH_DEST
*Oct 12 16:30:41.213: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=8889990*3051234567, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
*Oct 12 16:30:41.213: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=200
*Oct 12 16:30:41.213: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=13053284888, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Match Rule=DP_MATCH_ANSWER; Calling Number=13053284888
*Oct 12 16:30:41.213: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
Dial String=, Expanded String=, Calling Number=13053284888T
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
Result=-1
*Oct 12 16:30:41.213: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@6080
Match Rule=DP_MATCH_ORIGINATE; Calling Number=13053284888
Result=Success(0); Incoming Dial-peer=201 Is Matched
*Oct 12 16:30:41.217: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@6080
*Oct 12 16:30:41.217: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=201
*Oct 12 16:30:41.217: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Oct 12 16:30:41.217: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6708
*Oct 12 16:30:41.217: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
*Oct 12 16:30:41.217: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
*Oct 12 16:30:41.217: //-1/0CCD6A4BAD69/DPM/dpAssociateIncomingPeerCore:
Calling Number=13053284888, Called Number=8889990*3051234567, Voice-Interface=0x0,
Match Rule=DP_MATCH_VIA_URI; URI=sip:10.21.10.12:5080
*Oct 12 16:30:41.217: //-1/0CCD6A4BAD69/DPM/dpMatchPeertype:
*Oct 12 16:30:41.217: //-1/0CCD6A4BAD69/DPM/dpMatchCore:
Result=-1
*Oct 12 16:30:41.217: //-1/0CCD6A4BAD69/DPM/dpMatchPeertype:exit@6080
Match Rule=DP_MATCH_REQUEST_URI; URI=sip:8889990*3051234567@10.21.10.250
Result=-1
Match Rule=DP_MATCH_TO_URI; URI=sip:8889990*3051234567@10.21.10.250
Result=-1
Match Rule=DP_MATCH_FROM_URI; URI=sip:FreeSWITCH@10.21.10.250
Result=-1
Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=8889990*3051234567
Result=-1
Result=-1
*Oct 12 16:30:41.217: //-1/0CCD6A4BAD69/DPM/MatchNextPeer:
*Oct 12 16:30:41.217: //-1/0CCD6A4BAD69/DPM/dpMatchSafModulePlugin:
*Oct 12 16:30:41.217: //-1/0CCD6A4BAD69/DPM/dpAssociateIncomingPeerSPI:exit@6659
*Oct 12 16:30:41.221: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 488 Not Acceptable Media
To: <sip:8889990*3051234567@10.21.10.250>;tag=13446E38-1980
Date: Wed, 12 Oct 2016 16:30:41 GMT
Allow-Events: telephone-event
Warning: 304 10.21.10.250 "Media Type(s) Unavailable"
Reason: Q.850;cause=65
Server: Cisco-SIPGateway/IOS-15.2.4.M7
Content-Length: 0
Received:
ACK sip:8889990*3051234567@10.21.10.250 SIP/2.0
Max-Forwards: 69
CSeq: 97809650 ACK
Content-Length: 0
Everyone's tags (1)
2 REPLIES 2
Highlighted
Hall of Fame Cisco Employee
What codecs does your ISP
What codecs does your ISP support??
And are you using those in the voice class codec??
java
if this helps, please rate
Highlighted
Beginner
My carrier supports g711 and
My carrier supports g711 and that is what I have on the codec profile
voice class codec 21
codec preference 1 g711ulaw
