call not working between two cluster
Rakesh K
Hi Everyone
I am trying to make call from phone A cluster 1 to phone B cluster 2.
Call hits the Phone B and will click speaker button there is no audio and in phone A can hear call ringing tone, and the call gets disconnected after 8 seconds.
I have H.323 gateway on both clusters and no mentioned any codec on the router
I am testing this in my lab and there is no location or region set everything is to default. The phone is using sccp 7960.
12 Replies 12
did you verify that ip routing between Phone a and phone B exists?
From IP Phone A’s subnet you should be able to ping II Phone B
Please let me know.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Phone A is making a call to Phone B and its ringing, I guess this says the route is there right?
No.
That means that Cluster A can reach Cluster B and each Cluster can reach their own IP Phones.
Once the call is established, rtp traffic goes directly between IP Phones
Carlo
I just made a ping from router 1 to phone 2 and router 2 to phone 1 and it was a success.
is there any other way you need me to check.
That test could not be enough.
If Router A has an interface directly connected to IP Phone A , you can try to ping using extended ping or a ping with “source” option.
Eg.
ping 10.20.1.10 source 10.10.1.1 ( where 10.10.1.1 is the Router A ip address )
Please give it a try and let me know
Carlo
The Phone which i am using a softphone
Are both softphones?
If yes, try to ping from the pc wher softphone A is installed on to the other IP Phone/Softphone.
Please let me know
Carlo
success
Is there a firewall between 2 sites? If so, maybe the RTP packets are being dropped because of a policy.
Another thing I would also do, I would take a packet capture from both sides and see what's wrong.
Any firewall on the pc where Softphones are installed?
I will go to the lab and try to connect the physical phone and do a test.
Is there anything need to look for in codec configuration in router or cucm?
If even physical phone fails is there anything I need to look for?
When the call is established, run the following command on both gateways:
show voip rtp connection
and please post the output
Carlo
