02-14-2019 04:37 AM - edited 03-17-2019 02:07 PM
I have 2 CUCM 11.5 clusters.
Cluster A, when a parked calls reversion timer expires the caller remains parked and continues to hear MOH, and the phone is alerted every 10 seconds with a single ring.
Cluster B, when a parked calls reversion timer expires, the caller hears ringback, and the phone simply starts ringing like a new inbound call, the caller will even forward to voice mail if the user does not pick up the call.
For the life of me I cannot figure out where this change is configuration is. Everything under Service Parameters pertaining to call park is the same.
02-14-2019 05:01 AM
1) You need to check the individual DN from where you are parking the call. Go to Call Routing>Directory Number search for DN and look for park parameters
2) Compare this for Both CUCMs.
3)There are Three Park Timers
Park Monitoring Reversion Timer | Time To First Reminder to Retrieve call | |
Park Monitoring Periodic Reversion Timer | Period between Second and Subsequent Reminders | |
Park Monitoring Forward No Retrieve Timer | Total Time to Park Call. After which it is forwarded as per Park Monitoring Forward No Retrieve Destination |
*** Please rate helpful post &; Mark "Accept as a Solution" if applicable
Haris
02-14-2019 05:12 AM
Yes, sorry
I had looked at those as well
They are simply blank for all phones(that I checked) on both clusters
02-14-2019 05:36 AM
Compare the defaults under Service Parameters --> CallManager --> Clusterwide Parameters (Feature - General) section.
02-15-2019 11:51 AM
Yes, that is where all the timers are set, other then that, all the settings are the same.
02-16-2019 10:18 PM
