Call Parks between two CME systems?
dan hale
Level 3
Level 3
I Have two sites that are connected via L2L and using Dial Peers to call between the two sites. All works well with the exception of call parks.
Site A has call park already setup however, when Site A parks a call that comes in via its own PRI from PSTN that Site B needs to pick up. This never seems to work.
Has anyone used Call park across CME systems?
Dan
Chris Deren
Dan,
So, you have 2 CME systems and you want to be able to pick up a call from phone at one system which was parked on another?  If so, this is not going to work as Park feature is only local to the system.
HTH,
Chris
Chris Deren
Dan,
HTH,
Chris
Thanks Chris, if I cant park across CME systems...any suggestions?
Basically Site A answers calls for Site B.
What about Directed call parks if the configuration was programmed on Site B. Would a directed call park work then?
Dan
